90k interval on the 2UZ as well. There are very very few documented cases of valve damage from a broken timing belt on the 2UZ as well. There are several people in the 100 community who also choose not to replace the timing belt.All timing belt concerns on Toyota's are usually overblown if they are using Asin/Toyota (Spell) parts. I saw a Asin timing belt on a Tacoma that was never changed until 300,000 miles. It was truly unbelievable. The belt wasn't cracked and showed no signs it was going to break. That being said, Toyota seems to recommend 90K on those, not sure what a 100 series belt is suppose to be. There must be some sort of fudge factor they have with those belts, I wonder what it is.
From the menu at the bottom of the original post select “edit” and then in the title change the “wanted” flag to “found”Another nOOb quesiton...how do I mark this as found. I hate wasting folks time.
