I don't want to keep the "stuck in grand junction" thread going, don't want the thread title to worry anyone.
I want to try and figure out what is happening here, other than neglect by me in checking this on my rig after wheeling trips and before long trips.
About a 18 months ago at the 2008 wheel bearing packing party I did a complete front axle job on my 80 (I did not replace any bearings or take apart my birfs) I was late and definitely had to hurry through the 2nd half. (Please note I am NOT looking for blame or pointing fingers at ANYONE but myself. I had great mentors at the WBPP and I take 100% responsibility for any wrenching I did on my rig) Everything seemed great, then about 6 months or so later I noticed my steering was getting loose, then found a huge pile of grease/gear oil under my pass. front tire one morning. 3 of the knuckle studs were very loose, I think one was gone completely. Steering was very loose due to the steering arm being so loose. So I did another complete axle job to the pass. side, but this time I did do the trunion bearing. I put in all new studs, did not locktite them. I checked both sides at the next oil change a month or so later, and everything was fine.
Fast forward to this past weekend. With no symptoms at all, I had been driving around with only 1 stud on the passenger side and 2 on the drivers side.
I did not check them at the last oil change. The rig is sitting at Safari Ltd. in Grand Junction with a $1500 bill to do the whole front end again, new wheel bearings and trunion bearings (said the races are toast on the pass. side, the ones with less than 12k miles on them) and everything.
My main question is how are these studs working free? What would cause this? It seems like it happens after a axle job, but what could I do to the knuckle to make these studs work themselves free?? Hugh mentions among other things the bearing preload, which at the WBPP we used the fish scale for, but when I re-did the pass. side I did it by feel.
I do take complete responsibility for not checking them and this is now going to be a regular maintenance item, but I am just trying to understand how and why it happens, and maybe prevent it from happening again on my rig or to someone else. I also am not completely convinced that my driver's side needs to be completely re-done.
Anyway, thanks for reading, and if you have an 80 PLEASE go check your knuckle studs!
