• RS MAY CLUB MEETING
Jimmy's Electric Adventures
J1000
Morrison, CO
@DomOfTheDead @MonPetiteShoe and @On the RX are committed to possibly helping me out Saturday working on the EVJ80 :cool: Anyone else want to come lend a hand feel free to post up or PM me.
In other news I have been working on a heater. I decided to just completely skip electric heat and waste heat at the moment and go straight to a fuel heater. Cheap chinese "diesel air heaters" are flooding the market after the German patent expired. They are basically a small combustion chamber where fuel is pushed in and a fan draws in air and it's burnt to create heat. They are very simple but very effective. They are becoming super popular in the vanlife/RV/EV community.
I have one small problem with them: they run on diesel. I hate the smell of diesel like most people and hate getting it on my hands, shoes, car, etc and having the smell linger forever. I definitely don't want that smell in or around my EV. Some of these heaters are advertised as "gasoline air heaters" but some internet detectives claim they are identical to the diesel version with just the computer settings adjusted slightly.
I took it one step further and am running mine on E85. E85 has a much more subtle smell than gasoline and doesn't linger because it's mostly alcohol. The exhaust is also much more pleasant. Also compared to gas E85 has about 40% less lifecycle greenhouse gas emissions and burns way cleaner so I think it's the most green way I can run one of these heaters.
Today I screwed around with the heater and was able to get it running reliably on E85 fuel.
The two things I did specifically to run E85:
-Added Top Lube to the fuel to provide lubrication to the pump
-Increased the minimum Hz from 1.6 to 2.4Hz and maximum from 5.6 to 6.5Hz
So far so good! The heater has been running today for hours without running a beat on the new settings keeping my garage at 60F. The heat coming out of the vents is 180-190F. If I still had my LEAF I would install one of these in it!
I got this heater which is towards the top end of the chinese quality: https://amzn.to/3oHkj7v
Top Lube: https://amzn.to/3JjsmiR
My test setup in the garage currently:
Now the next question is where in the Land Cruiser will I mount this thing?? I'm thinking maybe in the center console but it's already getting cramped in that area. I really am stumped as I want to keep all 7 seats. Maybe I will mount it in a rear quarter panel area where the subwoofer goes sometimes.
MountainGoat
Club Treasurer
Evergreen, CO
Sorry for my underwear. It's been a long road trip. :ROFLMAO:
J1000
Morrison, CO
Dom and Josh came over and kicked ass again today on the 80. Time to get serious now if we are going to make it to Cruise Moab...
Dom got a bracket welded in to mount the PS pump. I got all the adapters now so I should be able to make up some AN fittings and braided hose to complete the PS loop. Funny coincidence the LC and the Volvo PS pump I have both use the same size 16x1.5 fitting.
We also got all 7 braided brake lines installed. Only one fitting rounded out! The small hard line on the passenger front caliper for some reason would not come loose. Will just replace it and move on.
Club Secretary
Is there room in one of the rear cargo panels for that heater? Especially now with no fuel filler hose in the way? And then maybe you could use the fuel door to add your E85?
tallmike
Brand New
Toyota is constantly sending me email telling me it's time for me to upgrade my 4Runner to a new 4Runner. I'm like, okay, what have you got in an all-electric 4Runner? <crickets>
DanS
Dumont
Valid question.
A full EV 4Runner would get me to a dealership, almost as fast as an EV 70 series.
Dan
J1000
Morrison, CO
Some updates. Firstly the brakes are basically done except the front passenger side is giving me a fight. Tried to make a new brake line but either the tube or the flaring kit or probably both I bought are too cheap and keep failing so I just ordered one. I got the power steering now completed but haven't put the wheels on the ground to test it under load yet.
I got the rest of my relay box wired up so everything works as it should (Inverter + Water Pump come on with key and charging, Vac/Steering/T-Case pumps come on with key only). I also got my radiator mounted up and fans wired.
Biggest news is I finally put the motor back in the truck! I cross-drilled and pinned the driveshaft on the motor end. The cotter pin should be fine or should I upgrade to a hardened steel pin? I'm going to get it aligned with lasers and then weld on my torque tube next week.
Lastly, I got a replacement black door and rear fender flare so now my truck is all the same color again!
You can see the broad steel plate face I added on which will be what the torque tube welds to.
New AN lines on my PS pump:
Again, not sure if a radiator this small will be adequate and I'm prepared to upgrade.
Cosmetics!
I find it funny that the sun fade on the fender flare from a completely different truck matches my truck absolutely perfect :LOL: (thanks Dom!)
DouglasVB
Baby radiator doo doo doo doo doo doo 🦈
That's awesome Jimmy! Still hope to bring it to Cruise Moab??
What's that cotter pin supposed to do? locate the splined joint axially? Does it have any load on it at all? Those things are usually pretty soft so I am not sure I'd depend on it for much if anything.
J1000
Morrison, CO
Keep the shaft from walking in and out of the bearing. I agree I'm going to upgrade it.
J1000
Morrison, CO
Could really use some help on my 80 if anyone is available this weekend to help out. Coming along slowly but surely
J1000
Morrison, CO
Specifically some of the things I could use help with are things like installing my center console and CB radio, figuring out how to make the grill hinge and securing loose wires and hoses.
I'd like to but my wife is going to the Bill Burke training and leaving me home w/ the kids and dogs.
