gas tank/ohms/and fun...
FJBen
0
So my gas gauge reads a little under half when full. Then quickly goes to empty :D But when I fill up at "E" It's usually 8.5 gallons (i have the 18.5 gallon tank)
Now I'm retarded with the multi-meters...but I think I got it somewhat working. I checked right at the guage and got 32ohms. Which should be right because I'm around less than half a tank. If i hookup all the wires and just put the probe into the connection...I drop to 26ohms...I suspect if I measure the ohms at the gauge they will be very low, thus the gauge reading off meaning my wires are having issues.
It's a 67...i'm sure the wires a poo (as I've already found) so I'm thinking about just running a new wire and a ground up to the gauge....BUT the gauge only works with power to it...so where is it pulling power from to make that guage work? Or how can i rewire to make that gauge work?
Shark Bait
Parker, CO
Have you thought about trying a different sender? When you ground the sender wire does it "peg" the gauge?
FJBen
0
I haven't tried that, Should it peg it to full I assume?
Shark Bait
Parker, CO
I know the oil pressure sender will. Not sure about the fuel. I think so.
