Fyffer's low oil pressure Chevy V8 issue
Daytonadogie
Lake City, CO
Lt1swap.com has all/most of the info you should need as far as engine wiring goes. He breaks it down to differences in years and models, shows how to modify a stock harness to work stand alone. He can reprogram the ecu to eliminate all the emission garbage. Hope this helps!
just Saw Jkimmel’s post. Didn’t mean to be redundant, but there’s a ton of good info there! Navigating through the website can be a little confusing though.
fyffer
Trinidad, CO
Took a brief look at the site, very intersting and good info. TY very much, may take me a minute to sort stuff out.
fyffer
Trinidad, CO
LT1swap, great source but dang does it overwhelm me.
So a Stand alone harness configuration for me, is a: -04 Chevy Express Blue PCM, Drive By Cable (DBC) with 4L60E Transmission. Multec coil connectors, Alt connector 4 cavity, MAF a 5 wire LS7 card connector. Delphi MAP sensor connector, NOT BOSH.
Now, chasing where to get them. Dug around a bit looks like ass a special order is needed.
J Kimmel
Glenwood Springs CO
Completely wrong transmission but I have one. It’s pretty good but it’s not quite dialed in yet. I have the extra bus module that reads the LS pcm
fyffer
Trinidad, CO
Anyone has any experience with Red Line Landcruiser shop (COS). If, please share cause I do feel (99%) certain otherwise that's the direction I am going. Want to make that decision this weekend.
No personal experience but they’ve been around a long time (usually a good sign) and they have a good reputation. Hopefully others with direct experience chime in
I think @Romer had a lot of work done there.
