I rebuilt the carburetor on my 73 FJ40. It would only start with starting fluid and didn't run that well. It's a Trollhole carb for those familiar, apparently a knockoff of the non-US versions. It's my first time doing this, and it fired up quickly and starts up every time now. The problem is that I can't get it turned down. With a cold motor and full choke, it races, almost like Wide Open Throttle. When I open the choke up it slows down but still way too high. I disconnected the throttle cable, so I know that's not an issue, the throttle linkage is free and operates smoothly, can close without issue. I've dialed the speed screw to the slowest setting, looking down inside the butterfly valves are mostly shut. What should I be checking next?
