Dad's 1978 FJ40
Nate
Aurora, CO
Very early on, like week one in the process, I decided on the Kwik Wire 14 circuit wiring harness. Once the body was mounted I started playing with 3D design for printing a bracket. In the end, the answer was to punch and thread a few holes in the back of the KW fuse block backing and mount it on the firewall.
Nate
Aurora, CO
The wiring battle has been going really since July. Trying to sort out the OG wiring harness that was torn out, the updated wiring harness that was abandoned, and the KW book. Coolerman's drawing is pretty close but it took some comparison between that drawing, the 2F FSM, the Chasis & Body FSM, the Haynes manual, here, and Mud to get it sorted out. I've made plenty of notes and will update the diagram to keep with this 40.
Nate
Aurora, CO
I took some sanity breaks with the wiring to get body parts on. Aligning them was a lot more difficult than I was planning. The rear doors especially drove me right to the edge. Brutal, because the captured nuts in the quarter panels for hinges are not captured. That is a major nightmare to get them aligned and properly positioned.
looks great!
Nate
Aurora, CO
More to come tonight, but sneak preview. I'm gonna need some help. When I try to start the engine I'm getting a gas mist backfiring through the carb and not sure where to start.
in da house
Bet timing might be off a tooth, I could probably come by tomorrow and help you if you need.
Nate
Aurora, CO
I was thinking that as well (after some forum work) and was gonna pull the distributor and reset it again. @wesintl if you're bored tomorrow your welcome to swing by. I'm way out in SE Aurora.
Nate
Aurora, CO
I repaired the lid and placed a new double thickness headliner in. This was my first shot at using in air sprayer for primer, paint and clear.
It came up pretty good. I used some RV self leveling seam sealer to take care of sealing all the rivets. It is stored until the end since it's too convenient to stand up inside the rig while doing all the internals.
Nate
Aurora, CO
Next was more wiring with the wiper motor, switches, and tail and side marker lights. I had numerous problems with motor and rotten wiring. I desoldered and resolder wires on several contacts because they were brittle they wouldn't take new pins. I'm using Deutsch connectors everywhere it makes sense to me to do so.
Johnny Utah
This is great! You’re doing a wonderful job. Can’t wait to see her when she’s done!
Nate
Aurora, CO
As hard as it can be to find stuff on his site, Toyota Matt from Mud has parts you can't find anywhere and Toyota connectors are not something you find on Amazon. Matt's headlight switch pigtail kit is on point. Huge life saver.
And those $30 Toyota headlights are impossible to beat. Look at the grill 🤩
Nate
Aurora, CO
Wish I could share the video, but I was able to use the KW built-in relates for the horn and the flashers with no issues. That cleaned up the wiring quite a bit.
ToyotaMatt also has the connector and plugs for the combination meter. I don't know he does because I spent hours trying to find the triangle style connectors for the combo meter pins.
Sister sent that magnet after she heard the video of the horn, which was also fully restored.
Nate
Aurora, CO
Quick updates to cover tons of work. You just can't photograph wiring. All the switches have been scrubbed and painted. And just added a new coil yesterday. Wired in the resistor, and am getting spark on 6 plugs confirmed via spark tester today. Photo below is with jumper as coil was net getting voltage. Turns out, I'd somehow turned off the master kill switch on the KW fuse block. 🤦🏼
The next photos are as it sits tonight. With the backfire issue I mentioned above. Will try resetting the dizzy after everyone goes to bed.
Nate
Aurora, CO
Oh! The seats have all new cushions and fabric courtesy Arthur at Auto Trim Specialists in Evans. They're on storage for now, but whoa. They came up nice. Photos coming later.
simps80
Arvada, CO
capturing how much work good electrical wiring is impossible with photos
this looks like amazing work and results!!
Nate
Aurora, CO
Yeah, and yet it would be some dang helpful to have a video or series of photos of some one doing one, but I've found there is so much variability in parts. That get tacked on and taken off over the years that it may not really be helpful to most.
Nate
Aurora, CO
After some solid advice from Wes and a video from the 40Channel on YouTube, I am at this point in the start-up. Super close I think. Any thoughts on why it won't catch? Still a timing issue?
Capriblue45
Are you sure you are not 180 out on the distributor, I have had engines act like this when they are 180 out? You can check by rotating the engine until you are on the timing mark on the flywheel and if the first and second rockers are not in contact with the valve and the rotor is roughly pointing at the #4 plug you are at TDC.
