Cool Things I Saw Online and Now I Want
Doughboy
Wonder how long before they are outlawed? Infinite possibilities for trouble. :hill:
I'm 99% sure these would fall under the 1st amendment and therefore protect as free speech and freedom of expression. No different then anyone having "baby up in this bitch" or 'how's my driving? Call 1800 eat shit" etc, etc.
rushthezeppelin
I think you're going to see these everywhere soon.
View: https://www.instagram.com/p/CmJqqDzjEYd/
I looked for them on Amazon. There are tons of options:
Sadly I'm just imagining this leading to threats of pulling a firearm. That happened to me in a road rage incident when I was in my early 20s. I don't think I ever even figured what I supposedly did wrong but the guy followed me for like 5 minutes off the freeway till I parked at a gas station and went balistic.
rushthezeppelin
glorifying high capacity magazines in light of all the mass shootings is a new low.
You misspelled standard capacity.....
Doughboy
I want this, I'm sure @Johnny Utah and the other vets here would want them too! The classic DD-214 blanket
MountainGoat
Club Treasurer
Evergreen, CO
Damn Angelo, I went down the rabbit hole on that website. Love it. (y)
MountainGoat
Club Treasurer
Evergreen, CO
This thing would be awesome for the 80...
HDavis
I wonder if one could make something like this with the ultra-gauge and a sacrificial bezel. I'm going to have to pull mine out and see how close it is.
MountainGoat
Club Treasurer
Evergreen, CO
Now that is cool.
Specifications: 1990 Toyota Hilux Double Cab​
Power
1990 Prado 1KZ turbo-diesel engine and intercooler
R150 5-speed transmission
RF1A dual transfer case
MC08 Marlin Crawler 4:70:1 gears
Suspension and Drive
5.29:1 axle gearing
Rear 9.5-inch full floating Land Cruiser 80-Series axle
Front Land Cruiser 80-Series axle
LC80 differential lock front and rear with air pneumatic actuator instead of electric actuator
Firestone Airide 9901 air spring suspension front and rear
Fox 2.0 10-inch shocks
Wheels and Tires
Toyo Open Country 37-inch tires on 15×12-inch steel wheels
Arctic Truck 405 38-inch tires on 15×14-inch steel wheels
Dick Cepek 44-inch tires on 15×14-inch steel wheels
Arctic Trucks Nokian 44-inch on 17×16-inch steel wheels
Mickey Thompson Baja Claw 46-inch tires on 16×16-inch steel wheels
Recovery and Armor
Warn XD9000i 12-volt winch in a cradle, mount front or back
Warn snatch block and some shackles
Elastic recovery rope
Briddebilt rear bumper
Tech Tire Permacure tire repair kit
Hi-Lift jack, 60-inch
Accessories
Auxbeam LED lights
York compressor with air tank, 10-liter
Auxiliary fuel tank, 100-liter
Dual band VHF/UHF radio
Recaro front seats
Garmin GPS and PC computer for navigation
Teltonika RUT955 4G router
230VAC 600-watt inverter
Two Optima RedTop batteries
FireMike
Lyons, Co
Now that is cool.
Power
5.29:1 axle gearing
Wheels and Tires
Recovery and Armor
Accessories
Auxbeam LED lights
Recaro front seats
Yes.... That is cool, And I want one!
twentyfooteighty
Salida, CO
not quite a clean, but then you can access the buttons on the rear of the UG. I have one on the way.
stusic
The Subaru doesn't have a temp gauge (only a too-late light), so it ended up with a blown the engine. Now that it's fixed, I had been meaning to add a temp gauge, but when I got mah wife a new head unit for xmas, I picked up a wireless obdII reader. Since the Torque app shows everything I'd need, including a temp gauge, I don't need to buy and install a separate gauge.
Pz10420
Can you set any kind of alarm limits on the temp for the app? And will this still work while you're actually using the stereo?- I actually had a similar set up quite a few years ago with a chinese android headunit in my old bmw and it worked pretty well but I never used it that often. But it was nice to be able to scan codes as soon as a CEL pops up on the dash. Not sure how much better they are these days but I would imagine quite a bit.
that's cool! I plan to do car play in the 4Runner and 80.
stusic
I haven't played around with it too much, but there are options for alarms. And you can play the stereo while using it (but they can't be on the screen at the same time afaik)
stusic
I really like the one I put in my truck (got mah wife the same one). Android based cheap jobby, but got the rear view camera and the dash cam. No OBDII on the 80, so that's not really relevant.
Edit: I should probably at least mention the head unit is an Atoto S8
