I’m thinking about moving my HAM antenna off my front ARB bumper and to the rear of the vehicle to make room for a GMRS up front. I don’t want them both up there. The passenger side is not too distracting but I don’t think I could handle one right in front of me.
What’s the thought of cutting a 12” round or square piece of 1/8” steel and mounting that above the spare tire to act as a ground plane and then centering the antenna on that surface. Do you think I’ll gain or hurt the performance of the antenna? Reading about home built ground plane antennas it seems most have the outriggers the same length as the antenna itself. This will not be the case here.
A roof top mount is not possible. I’ve had the fender style mounts up by the cowl of the hood but I simply broke too many antennas on vegetation. I did the upper hatch mount at one point but that is not ideal with the RTT and awning.
Current antenna is a Comet 1/2-wave (2M). Seems like every time I remove an antenna the base fails and breaks due to corrosion. So I could be forced to buy a new antenna, could change to a different size/model/style. Wouldn’t really want to go any longer unless foldable.
www.cometantenna.com
Or is this a waste of time and just mount it anywhere on the tire swing arm all Willy Nilly and just go wheeling. After all my antenna is ground independent.
See red line in picture. Tire is a 12.5” so I don’t want to go any wider than that for the steel base.
Comet - SBB-5NMO - 2M/70cm Mobile Antenna (BLACK) - cometantenna
DualBand 2M/440MHz mobile antenna This is the most popular antenna in the Comet line for several reasons: Mid-size / mid-price range / open coil flexs to absorb brushes with tree branches / black color fades into the skyline – ground independent Gain & Wavelength: 2M: 3.0dBi 1/2 wave 70cm...
