DouglasVB
Well I'm this deep... Maybe I should rebuild the engine too?
Looks pretty good in the transmission gearing. There are some gears with groves and chips but nothing bad. Looks like it has another 100k miles before I'll need to worry about anything.
There is probably a small leak from the rear main seal on the engine but it's extremely minor. Just a couple drops of oil in the bell housing. It could also be residual from when the oil pan was leaking.
I suspect my water pump might have a small leak. I've found some unexplained coolant while taking the transmission out. The area around the water pump is kinda moist. I've lost about a cup of coolant in the last four hundred miles. Doesn't seem too bad and it could still be equalizing in the coolant system after replacing the radiator.
Sent from my SCH-I545 using Tapatalk
