DouglasVB
No new bolts needed. If you want to use fip in conjunction just use a thin layer each side.
So FIPG needed if I don't want to? Sweet! One less trip to Stevinson
I put a thin layer of FIPG on both sides of the gasket. Not sure if Justin is suggesting no gasket or not.So FIPG needed if I don't want to? Sweet! One less trip to Stevinson![]()
The truck is all back together. No leaks so far. I'm going to take a longer test ride this afternoon.
The bushing in my front suspension driver side rear shackle is definitely failing. I can see daylight through between the shackle and the frame now. I'm guessing this means I shouldn't be driving too far or too fast until I can find a replacement and get it in there...
I wouldn't. Should be able to get a bushing locally pretty easily though.
IIRC you have all pro springs not trail gear. Here are their bushings
https://www.allprooffroad.com/pickupsuspension/277
Was that the way it was in the SAS kit?Yeah the frame-side bushings in the back of the front suspension (so the upper shackle bit?). 1.5" OD! It's an 18mm bolt that goes through. No sleeve.
That seems about right for a frame-side bushing. That would equate to approximately an 80mm shoulder-to-shoulder width. You don't want the two bushings to touch in the middle but also not have a ton of space between them. The spring-side OME bushings I used were 30mm mm long and frame side were 37.5mm long.I'll grab a measurement later on the width from the truck. The bushings that are in there now are 40mm long. I am pretty sure they're what came with the original SAS kit when it was done 10-ish years ago.
