Is one of your motor mounts broken?
Do you have the stock PS pump? They generally use ATF, not PS fluid, which will leak if used. Is whatever is in the reservoir the same as what you are seeing leak?
I've used Airsoft BBs in my Rockers for years, and it works OK. If you can get them balanced normally, though, that's better.
Mark
Not that I can see. Both appear to be good although I might not know what I'm looking for. I'll drive the truck to the meeting tomorrow to get some opinions.
The fluid in the PS pump doesn't look like the fluid in the engine bay. The fluid in the PS looks dark while the fluid that's sprayed on the passenger side of the engine bay and out onto the shock and shock tower is clear. No clue if it's the right fluid in the PS system or not.
I think I'll try getting one of the local tire places to give a shot at balancing these tires. If that doesn't work, then I'll go the Airsoft BB route.
Hmm that might be why it vibrates so much at startup. Are you going to be at the meeting on Wednesday, Bill?
I seriously doubt it, it's my wife's BD.
(Dave had commented about the mystery clear oil maybe coming from the diffs up via the ARB air locker hoses and compressor, and spraying out from there. Looks like the comment was deleted though?) That's actually a good idea I hadn't even considered. I thought the ARB air lockers are supposed to be sealed though? Otherwise wouldn't you end up pressurizing your diff housings? I have been running the compressor to air up the tires. When I went up to Yankee Hill I did briefly engage both the front and rear lockers when I was at an odd angle in some snow (they worked great!) but otherwise they haven't been engaged. maybe the drive over the passes and down again caused some diff fluid to work its way up and spray out?
they are sealed but when the seals start to die, they will suck diff fluid into the lines eventually expelling out the solenoids
I'll look more closely tonight to try and identify the fluid. It could be gear oil and there isn't enough of it to make a strong smell. Maybe it's time to do a taste testThe truck will come with me to the meeting tomorrow night so we can all take a gander at it in person. I'm working right now on finding somewhere that can try to balance the tires. So far no luck. Everywhere is either booked until next week (I didn't even know that was a thing at a tire shop!) or won't touch the tires.
Max (74fj40, I think?) here on the forum works for High Country 4x4. They'll balance them for sure. If you have a vibration that changes when depressing the clutch I would put my money on rear u-joints.
The rear u-joint would still be spinning when I press in the clutch though? Is it because the load is removed so it can spin freely?
