DouglasVB
AHA! I found the missing gear! It was in a differential rebuild kit box. No clue why I put it there.
Now to find a place with a press open on Sunday...
Could be the source in front for sure. I was thinking the back leak, it's not uncommon to think rear main when it's just the half moons.Or the distributor o-ring.
Are the leaks engine oil or gear oil?
You may be aware of this, but if it's engine oil and doesn't appear to be coming from inside the bellhousing (which would be rear main seal), it's very common that the half moon gaskets leak, which covers the back side in oil. Some people recommend using RTV but I found that just replacing them once in a while was fine. The rubber tends to dry out and loose its compression from the exposure to heat and oil.
Or the distributor o-ring For the front leak....
I know you haven't had a chance to wheel it yet, but how do you like the feel of the new gear ratios you have?
Mark
