DouglasVB
From Marlin's site:
In our opinion, the Ultimate setup is when a dual transfercase is built with one set of stock gears (2.28:1), and one set of Marlin Crawler's 4.70:1 gear sets. This is known as the Dual Ultimate Crawler. In a 21-spline application, due to the excess torque generated by the 4.70:1 gears, we will only build a 21-spline Ultimate Crawler with the 4.70:1 gears in the back case. But in a 23-spline application, the factory 23-spline input is much stronger, and therefore, the 4.70:1 gears can be placed in either the front case or in the rear, the choice is yours. In any of the available applications, two sets of 4.70:1 can be used to achieve a low range crawl ratio of nearly 500:1! More than 9 times lower than stock! We call this a Dual Ultimate Overkill Crawler since such a low crawl ratio is merely for bragging rights.
The transmission, unless it's been modified, has a 21 spline output. It's the W56 transmission. There could be a 23 spline coupler between the two cases though. I don't think there's any way to tell without dropping the T-cases and counting splines.
