Adventures in 4Runner'ing
ToyodaTocco
Aurora
There are some convenient places in the harness both in the engine bay and in the dash that you can interrupt to prevent the truck from starting. Mad Max Fury Road is a good source of inspiration for interesting switch patterns to immobilize the vehicle. I'd rather not publicly disclose my specific scheme for immobilization on a public forum. :thumb: However I can show you in the wiring diagrams some convenient places to dig into.
My buddy with the 2WD truck in Oregon just lost his engine last week due to head gasket failure between cylinders 3 and 4. He's swapping engines at the moment. I'd rather not have to do that anytime soon. Is it worth doing a head gasket job now as insurance?
Are there any other major or minor service items that I should be doing ASAP that I haven't yet (or that I'm not going to do in the next couple days)?
You should do some testing like DaveinDenver suggested. Since mine is a daily driver also, I picked up a 22r builder motor off of craigslist and rebuilt it. Then once I was done, I swapped it one weekend. You would want the laser cut block. They pop up here once in awhile and on craigslist. Don't pay too much for one!!! Just in case the block is cracked or bad. I can help you out if you like. I really enjoyed rebuilding mine and have another 22r that I plan to rebuild (because everyone needs a back up right!:D)
Yes, an engine compressor gauge is pretty cheap at any parts store. You remove the spark plug and thread the tube in. It ain't rocket surgery.
The cooling system tool I have is an Astro kit. Handy for finding leaks, too. Usually hoses only leak when they're hot and the water pump is spinning fast, e.g. you're driving down the highway. My wife doesn't like holding on to the hood to find the pinhole in the radiator, so, you know, that's why I got the kit.
DouglasVB
Haha Bill you're a bad influence! But it is nice having a spare engine on hand and ready to go... Hmm... they only weigh like 300 pounds? I could keep one of those as a spare in my parts box in the back... Drive around on the 4x4 roads and offer a spare engine at a ridiculous price to anyone with a blown engine... yeah that sounds like a good idea... :D
I'm actually a bit space constrained for storing a spare engine or rebuilding one. My motorcycle projects have eaten up my half of the garage. Although if you'd like to take a great condition 1979 Yamaha XS1100 Special with the king and queen seat off my hands...
DouglasVB
I just watched a how-to video on compression testing. It looks super simple. Would it be wise for me to add a compression tester tool to my toolbox? I could pick one up at an autoparts store on the way home pretty easily.
It looks like the Astro kit is going to be one I borrow for sure. $$$$ :thumb:
Just so it doesn't sound too exotic, this just means a later 22R block, made after 10/85 (I think) up to the end of production in 1995. Basically any 22R-E after 1985 is a laser block. They're not laser cut or anything, I think it just refers to the way they put the casting number in it, laser etched instead of stamped or rolled.
In any case, you can't just go swapping between pre- and post-85 parts. The deck heights are different, the laser blocks are lower. So if you put the head from a 1985+ on the 20/22R block from 1979-1984 you'll get interference. Vice versa, an early head on a late block will increase your compression, which might be OK if you have the components to take advantage of it. Also other stuff changed over the years, the throttle bodies, fuel injectors, harnesses continually changed so you have to be careful about mixing and matching.
The part number is Astro 7858, I think it's a couple of hundred dollars.
ToyodaTocco
Aurora
Oh, I know the feeling! I'm not trying to say to rebuild it but test it first. If it passes the test more than likely, a valve adjustment would do the trick. If not a top end rebuild would be quick and relatively painless. A new head from engnbldr and gasket kit and you could have it done in a day.
AxleIke
Perfect! That's exactly what I needed to know. I'll probably bug you more in a couple months when I start assembling all the goodies for the build. I was looking through the Marlin Crawler website to try and figure out if it's cost-effective for me to throw gears into a second transfer case and rebuild my current transfer case with the 23 spline output shaft or not. It almost looks like it's lower cost to just send them two transfer boxes and get back the complete ultimate setup they have.
Another question: 27 vs 30 spline drive shaft? Worth going up spline count on this or sticking with factory? (at least that's how I currently understand it... my knowledge here might not be right)
Yes I would rather regear only once than come back for a second set of gears to bump up to 5.29:1 (I think that's the preferred next step up?). However, I'm not sure how HUGE I want to go with the tires. I still want to be able to make this a daily driver and not have a $3k/yr tire budget. Also I want the overlanding aspect to be there and not just a gnarly rock muncher.
I've been eyeing the All Pro Offroad SAS kit for a few weeks now and it looks like I'd gain at least five inches of lift up front from the kit with a possibility of 6" if I wanted it. I'm aware of the concept of too much lift so I guess that's why people cut into the frame to sink the shackles into it a bit to reduce lift height? Do people redo their frames very often to make them mimic the 1985 and earlier frame design? Long ago I did some work with frames on semi trucks and at least in that industry it seemed pretty common for people to slice and dice their fames in all sorts of inventive and possibly destructive ways.
Maybe there will be a few 35" or 37" shoed minitrucks on the Argentine Pass run this weekend so that I can check out what that looks like.
This all would have been easier if I could have found a 1985 4runner :lmao::lmao::lmao:
27 splines it is then!
I agree. And that's before lift from the upsized tires. Next time I do a huge 4runner build, I'll be sure to sit on my thumbs long enough to find a 1985 that is mostly rust free. This time I waited a year before I found my 1988. Waiting is HARD. :p:
See, this is all Dan's fault. If he hadn't spoiled me with testing out his stock 1985 with solid axles, I would probably have stayed happy and ignorant with my IFS. :lmao:
More seriously though, I don't want to end up with a minimonster truck at least on this build. I'd rather have something scrappy than a brute. Hmm I'll have to look at my chassis and body a bit to see how hard it would be to do major frame modifications.
By 27 or 30 spline, I assume you mean axles. Not drive shaft. Drive shaft (colloquially) refers to the shaft connecting your tcase to your axle. Dave is referring to the birfields, or front axle shafts. I disagree with Dave, and would go 30 spline, but thats just my mentality. I've done enough things where I didn't build it strong enough and was super annoyed about having to go back and redo it later. However, if you stick with 33's, stock birfs are fine. Larger, and I'd go with 30 spline chromoly stuff from RCV or similar.
For your project, you WILL need to get your driveshafts done. You will need to shorten the rear and lengthen the front for the dual transfercases. For the front, you will need a long travel slip (the splined section) as your current IFS shaft has almost no slip (diff and tcase are fixed front to back in relation to each other. Solid axle moves a bunch).
Now, onto your question about frames. Don't beat yourself up about not finding an 85. For what you want to do, you would be lifting it anyway to put on an IFS steering box, and high steer, like I said. The factory solid axle trucks have Jsteer which does not like to hold up well under wheeling abuse as soon as you go bigger than stock tires (shares a lot of that with the IFS trucks LOL). Most people upgrade their 85 and earlier trucks this way.
The frame modification for an IFS truck (frenching the leaf spring hangars) is VERY minor. Modifying it to mimic the 85 frame swoop over the axle is almost never done with leaf springs.
It is done a lot with link suspensions, because you can tuck the axle up a lot more with links, and get a much lower ride height. I did this on my 89. Cut the frame off just infront of the cab mounts in front of the door, and completely redid the front frame. This was to try to achieve a 20" or so frame height on 37's, 18 or so on 35's.
You can see here where I cut, welded, and fully plated all the seams on the 1/4" rectangular tubing. This truck was being linked, with an FJ80 front axle. The other advantage of going this way is that it gives you a MUCH stouter base to weld all of your link brackets, steering box mount, coilover mounts, etc... Rather than trying to plate the 1/8" stock frame. (disregard oilpan and such, this truck was swapped to a 3.4L V6.
You can also see the high steer arms (though these are not what you will have for a mini truck or 60 series front axle).
This is NOT worth doing on leaf springs, in my opinion. Way too much work for almost no benefit. Leafs sit higher. Just the way it is. You also have to push the motor up to go low. You will start hitting your oil pan before you get into the frame much.
My recommendation is to just do a kit. You can get lower than 5". A very popular front spring option is called "rears up front". You build custom leaf packs from stock rear springs that you get from a junk yard (very cheap this way too). You can dial in your lift however you want, usually in the 3" or so range, but you can go up from there if you like. They also have an offset spring pin location (axle is not centered on the spring, it is moved forward a tad). This gives you much better clearance for the rear of your fenders, but means you need to move the steering box forward more than you do on a SAS with a centered spring pin.
DouglasVB
DouglasVB
I was previously thinking that I might be able to piece together a kit for less money than a complete kit from All Pro Offroad or one of the other SAS kit suppliers. Aside from the springs, I don't think I'm going to find much of the other components in a normal junk yard though. But if I can end up with like a 3 or 4" lift rather than a monster lift, that might be worthwhile.
Neat job on the frame remanufacturing!
DouglasVB
Great. Now I'm drooling over engine components on Engnbldr. :perry:
I built my engine using an Engnbldr RV head with oversized valves and 261C cam. I wouldn't buy one again. Just me, though. I'd spend the money on a Vortec 4.3L conversion if I had it to do over. There's no substitute for displacement (or forced induction). If there ever was a textbook example of polishing a turd, this is it.
DouglasVB
Ooooooo that's pretty.
I'll probably change my mind in a year or two but right now I'm content to have my 22RE slowly chugging up the mountains. It's kind of fun to have a motorcycle that produces nearly the same horsepower as my 4runner. :cool:
There's nothing wrong with the 22R-E, it's reliable, easy to work on, does the job. My point is only that I wouldn't spend any real money rebuilding (or building) one again. Just keep it running, replace with a cheap runner if necessary and plan for a conversion.
If a GM V6 isn't your cup of tea, I would consider the 3RZ-FE (2.7L from the Taco) like Marlin or maybe (just maybe) 3L-TE diesel. My build was almost 10 years and 100K miles ago now and I certainly had a lot more dollars than sense then.
My path now is to move to a Tacoma that already has all the stuff I need, 245 HP V6, selectable locker, cruise control, air conditioning... I need to unload another WilderNest, then I can take the one off Imelda (it'll get stored where my backup currently sits) and finally get the truck ready to sell. It needs a few things fixed, a good cleaning and fingers crossed.
ToyodaTocco
Aurora
You have to drive the 22r like a two stroke 125cc dirtbike. Throttle WFO and feather the clutch!
DouglasVB
Were I to do some sort of swap, I'd probably go the turbodiesel route or maybe propane. Both interest me for nerdy engineering reasons. At that point though, I might get an Isuzu cab-over box truck four door with a turbo diesel plant and manual transmission (I know all the arguments against manual but I still prefer manual) and convert it into a crazy frankenstein 4x4. Quiggly and Sportsmobile will have nothing on that crazy Isuzu!
My 22re will probably stay forever so I still have at least a little beer money. :beer:
The newer Tacos are nice. I was considering buying a four door model before I took the plunge on my 4runner. The big turn-off for me is head room. I would have to shave the driver seat down about two inches to be comfortable with my head not hitting the ceiling.
DouglasVB
Will the 22r then also make the same sound as a little two stroke?
RINGADINGDINGDINGDINGDING!!!! :moto:
AxleIke
Dang, you are tall. And you fit into the 4runner? I always joked about the origin of my 4runner with my friends when they complained about the interior size of my 4runner being really small. However, that is off color and not for here :D
DouglasVB
YEAH! I do! I was more surprised than anyone! All of the current "minitruck" offerings from Japan have lower ceilings than my 4runner. Now, to be fair, the front seats in mine are pretty beat down but I have a good two or three inches of head room. In the current Taco, I have zero or a half inch if it's the end of the day. In the Nissan I've got just under an inch. Add a ball cap and the little dot on the top of the cap hits the ceiling and my skull.
I actually find the interior of my 4runner more roomy than my '04 Subaru Forester and a more comfortable driving position. Everything feels like it is in the right place.
I'm not TALL but I have a very long torso. 6'2" but with a 33" inseam on a good day.
