New winch and roof basket trial
I ended up going with the Harbor Freight winch. I decided that I'll probably do something stupid to break my first winch thus I am using this as a "learning winch" and I am totally fine with it dying within a year or two.
I opened up the winch and it looks like the guts of every other winch on the market. Sometime in the near future, I'll do some minor waterproofing work (lube silicone seal with silicone grease, use some caulk to seal up the electrics box etc.), lube the cable, and get a cover that fits over the winch. I'll have to probably do a little more cutting on the plastic grille to make a cover fit. The mounting points make the winch push up into the grille just a little bit. Not bad though.
Also, yes, the electrical box is held on with more than just zip ties. The zip ties are extra.
It looks good on the truck.
Nice, big battery cables. At some point soon, I'll be upgrading the battery.
Interestingly, it appears that some of the smog equipment has piping that is co-located with the air intake hose that runs from the throttle body over to the MAF sensor and air box. That will make it difficult to relocate the air box to the passenger side of the truck and battery to the driver side side (the idea being that I will then have more room for dual batteries on the driver side and a snorkel can eventually go on the passenger side).
I also test fit the hitch cargo basket I bought at Harbor Freight onto the roof rack that came with the truck. I will remove the hitch bar and have a buddy weld it together so that it will be narrower. I also need to figure out exactly how I will connect it to the roof. While the old Yakima gutter mounts and metal pipes could work for a season or two, that's not a good long-term solution, especially when going through areas with low hanging branches that want to rip roof baskets off.
I want the roof basket for several reasons including:
- Storage for luggage when out and about with friends
- Mounting points for antennas
- Convenient location to put axe and shovel
- Good mounting points for off road lights
Any thoughts on good mounting schemes are appreciated.
Maybe next week on Friday I will be making a visit to the Yota Yard to get the parts I need from there.
I'm hoping next week to also have time to do some more substantial welding to attach the sliders that have been sitting in my garage since July.
