treerootCO
- Joined
- Aug 22, 2005
- Messages
- 5,422
TOYOTA LAND CRUISER FURTHER IN ALL TERRAIN Chassis court tolé is the starting point of a long line of 4x4 Solid vehicles, reliable, efficient in all circumstances. The land cruiser passes through a steep slope, steep slopes, trenches into mounds, its chassis with riveted ladders, its rims reinforced, its mechanical organs firmly protected by a tower All this makes the Land Cruiser an invincible tool that stands the test of time. The performance of the 3.4-liter diesel engine allows all exits in the forest, in the mountains or on the sand. In case of difficult passage, the gearbox coupled to the transfer with gearbox offers eight forward and two reverse speeds. And the Land Cruiser is not exclusively a 4 x 4 vehicle: you can always drive in two-wheel drive and even release the front wheels of any transmission. This is the system of freewheel hubs, standard on all Land Cruisers exists in regular gasoline version (cylinder capacity 4.21).
TOYOTA LAND CRUISER: FURTHER IN THE NATURE Medium-sized chassis: 36 cm longer in length compared to the short chassis of which 14,5cenemassage, a removable cover in particularly robust coated fabric, this Land Cruiser offers more space for a reasonable size . Adapted to all-terrain, comfortable on the road. The medium chassis is the ideal tool on the farm, on construction sites, in the mountains and for all utilitarian functions. The two rear doors open wide for ease of access and loading. An area of 2.3 m2 is then available for transporting straw bales, plow sowing motors or cinder blocks. The remarkable flexibility of the 4-cylinder diesel engine 21.6mND to 2200RPM DIN and the quality of the suspension allow long stages without fatigue. Because the Land Cruiser can both drive at 115 km / h and climb thanks to the speed reducer a slope of 45 °. In addition, the free-wheeling system at the front allows quiet and economical driving. Further on the road, further in charge, further into the nature ... Here is the Land Cruiser
TOYOTA LAND CRUISER: FURTHER IN THE ESCAPE Towing a boat or towing a caravan requires power and stability. The Land Cruiser medium chassis has both. The 66 kW at 3500 RPM DIN are always available, and the longer wheelbase better distributes the effort on the axles. With or without trailer On the Land Cruiser everything is planned to go far and take full advantage: 2.70 m3 at the bottom contain your luggage and your equipment (skiing, diving, Sailing, fishing ...). On the Land Cruiser, pleasure is always there. Vigor of the lines and panoramic height, a monument of serenity. A ray of sunshine makes you take off? Remove the vinyl cover and breathe in full lungs. If it is really beautiful, remove everything: the tarpaulin and the doors, lower the windscreen. You get a fantastic four-wheel drive convertible. Dominate the ocean and land on the beach: your Land Cruiser has not forgotten to be anti-comosion. Fly to the heights: never a car will have taken you so close to the peaks In Land Cruiser, live the unforgettable and forget the constraints. The adventure is at the end of the road.
TOYOTA LAND CRUISER FURTHER IN THE SERVICES Chassis long plate: thanks to its four-wheel drive, it is the ideal vehicle for the links to the most inaccessible shipyards. The interior space is not counted. At the rear, the available space is 340 m2 for a cargo volume of 4.18 m3. Access is facilitated by the two half-hinged doors opening wide and the threshold lowered to the maximum. The LandCruiser is also a truck capable of accepting heavy (more than one ton!) Or bulky loads of 2 meters in length!) In addition, it is capable of towing three Tons, with trailer braked. These are qualities that will serve many professionals practicing their trade in difficult terrain conditions
TOYOTA LAND CRUISER: MORE AWAY IN THE SPACE Who did not dream of being able to leave in the early morning, with friends, for a hunting party in the countryside? The Land Cruiser long chassis allows all the escapades, in all seasons. Muddy paths, forest trails or steep slopes are no longer inaccessible. To defeat all obstacles, the Land Cruiser has a valuable asset: its powerful and enduring 4-cylinder diesel. Against the bite of the cold, it has a spacious and perfectly sealed cockpit. Heating with two-speed ventilation ensures a gentle heat even when the thermometer is below zero! But the Land Cruiser also loves summer. By opening the rear quarter windows, you create a delicious fresh air change. On the trail of the big fauves of Africa, as for a fishing party on Sundays. For the handball team as for the group of mountaineers. In a long chassis, the TOYOTA 4 x 4 discovers a new dimension in the off-road space.
