2UZ swap into 1992 FJ80
Wow holy hell that’s amazing man. Soooo stoked for you dude. So that tiny bit of excess air had the fuel trim pegged on that one side?
Johnny Utah
This is great Nick! I’m impressed with your patience and perseverance. Good luck with the testing, looking forward to seeing your passing results.
Stuckinthe80s
Yeah, crazy, huh?
this is too cool! Congrats on getting this sorted, finally!
AimCOTaco
Longmont, CO
IT'S FINALLY F_ING READY!!!
YES!!! This is so awesome to hear, I've been loosing sleep thinkin' about it, all hail White Stripe!
jps8460
Hell yea brother!!!
Hell yeah Nic!! Congratulations dude! Well deserved!
Stuckinthe80s
I meant to post these numbers...
Do the environment a favor and 2UZ swap your old land cruiser 🤣
FunkyYota
Evergreen
Hey Nic, I’m currently reworking my harness for my swap. One of the things I’m gonna try to add in is cruise control. Did you end up getting that working for your rig?
I’m trying to figure out two things right now:
  1. If I should make a circuit to convert the vss to a digital input for the ecu or if you bought this thing and had success https://sirhclabs.com/product/cortex-ebc-speed-sensor-adapter/
  2. How to best control cruise control. Did you measure the resistors in the 100 series cruise switch by chance or know if the 100series cruise control stalk fits in the 80series spot?
No idea if this is relevant but for the LS swap apparently I am to take the cruise control ECU outputs into the PCM inputs. Also, for the 1996 LX450 found this funky voltage output from the cruise control ECU Black-White wire into the Start circuit. It was about 11.9 V and seemed almost no current but was enough to cause the GM PCM to cycle the starter solenoid. According to an expert the circuit is there to cancel the cruise control in case an 80 owner turns the key to start while driving (cruise control was new-ish back in those days). For now the CC ECU is unplugged. When I hook up CC I expect to de-pin and cut that wire.
