As the thread states, this will be documenting the 2uz swap I'm doing on my 80 series. It won't be exactly like other build threads you may have followed as I'm already about half way done with it. The main point of it will be to cover some things that I haven't been able to find on the interwebs and lessen the strain on people doing this same thing in the future. I have a tendency to overthink a lot of things, which leads me to a lot of questions. If those questions can't be answered by doing research online, then I'm going to try to post the answers here. And, if I did find them online, I'll post the associated links here as well.
The types of things I'll cover:
There is a lot of debate on whether or not the 2uz swap is "worth it" but I won't entertain that discussion in this thread. This drivetrain made itself available to me for basically free and it is going to be substantially better than that poor little 3fe. Well, the 3fe isn't really little and that's the irony of it, right? I didn't weigh it nor the 2uz but I would guess the 3fe might be heavier with around half the power.
The engine/tranny/transfer case are from my dearly departed 1999 100 Series. The vehicle was totaled last year after an accident but I was able to buy it back from the insurance company and part out what goodies were still usable. This is really the reason I chose to do this specific swap as I had a complete donor vehicle and I know the history of the drivetrain. I think this is important to note because 2uz swaps can get even more complicated than they already are if you don't source everything from the same vehicle. I have the matched ECU and electrical bits to get past the Toyota sorcery associated with the immobilizer setup. But we'll get into that later.
Here are some threads/links that I have referenced quite a bit during all of this:
https://forum.ih8mud.com/threads/building-barbara-fj80-build-thread.1168819/ - from our very own Tyler @FunkyYota
https://forum.ih8mud.com/threads/project-effjjay-eighty-2uz-powered.341445/
https://forum.ih8mud.com/threads/2uzfe-swap-into-fj80-building-in-progress.273882/
https://forum.ih8mud.com/threads/fjbrobris-lx450-build.913274/
https://forum.ih8mud.com/threads/91-3fe-to-2uz-swap.1263929/
There's really not a lot of threads on doing this as the availability of these drivetrains is extremely limited compared to LS swaps. Also, I think a lot of difficulty shown in the documented swaps comes from trying to piece everything together. As previously mentioned, and this goes for any swap, it is probably easiest to have a complete donor vehicle if you want to do this yourself.
Here is a link going over the wiring for the 1uz which might be helpful:
https://www.clublexus.com/forums/ls...o-wire-up-a-1uz-engine-vvti-and-non-vvti.html
If nothing else, it helped dumb down the thought process on how the ECU interfaced with everything.
So without further adieu....
- Things I've learned along the way - mostly electronic stuff.
- Things that I couldn't find anywhere and had to figure out with the help of friends.
- Lessons learned during the build, during shakedown, and after long term use.
- Details on engine/tranny mounting as it's already been covered in other threads. Also, this will probably differ slightly in each application so it's up to you to make sure everything is where it needs to be.
- Things I forget about.
