Shark Bait
Way cool guys. What's all that spaghetti?
Way cool guys. What's all that spaghetti?![]()
Absolutely no idea. Wanna come help figger it out?
T
Timm, I can bring my 40 over sometime if you want compare. I have essentially the same setup. De-smogged 2F mated to a 3speed. (it passes emissions without any smog gear). The only difference is that I have an earlier carb.
Please!!! Would love to compare and take pics....anytime!!
My take would be to rip most of it out.![]()
To-Do List for Moab: (only 4 working weekends for me)
-Get Engine Running and desmogged.
-driveshafts
-exhaust
-check and probably overhaul brakes
-maybe..swap in FJ55 axles...rear locker (no brake cylinders right now) and front disc brakes...which would mean more brake work
-hopefully install lift and front locker
-sliders. IF SROR is not too swamped.![]()
-seats
-gas tank
-1 afternoon to paint the fender I stripped and various other touch ups
-new tires
Oh, and my kitchen remodel is not quite done.
Oh, any my wife is 3 months pregnant.
Oh, and work is crazy.
fuggetaboutit. Not enough timei gotta disagree there. before you do driveline, just swap the rear pumpkin (if you're hustling, figure about an hour, two if you're screwing off). the front axle swap complete, before you do the brakes since you'll have the brake lines off and you'll be pulling a valve out of the master cylinder, and buy a set of ubolts ahead of time ($60-75). figure on about three hours since getting the spring center pins to line up often requires a come along between the springs.![]()
Don't really need 'em on a 40 - that's mainly a wagon thing
I've got extra dual brake lines for a 40 if you want them. Then all you would need is a booster and dual master. I've also got a set of replacement disc brake pads I just bought off Nakman for $20, if you want those too.
You still want that bumper?![]()
Yes to all of the above please.
T
6. seats. have 2 yucky pairs of seats. If Ricardo had not ripped them to shreds...![]()
THIS would get me to Moab....hopefully...and of course registration and smog. No problem, right Ige?![]()
i wouldn't move the whole axle, just the locker or the diff.1. Either move locker from FJ55 axle to the 40 or throw on the whole axle. Would involve some more brake work as that axles has the brakes stripped. No hurry for the front disc brake axle as that would add a lot more time.
