What is the difference between an RCI Horizon and an RCI Ascent roof rack for a 3rd gen Taco?
Does anyone know what the difference is between the Horizon and the Ascent roof racks that RCI makes for 3rd gen Taco double cabs?
https://rcimetalworks.com/brand/rci-offroad/p-rci-taco-05-roofrack-dc-ascent-roof-rack-05-23-tacoma/
https://rcimetalworks.com/brand/rci...-roof-horizon-horizon-roof-rack-05-23-tacoma/
The photos are identical. All of the descriptions are identical except for the weight (the Ascent weighs 7lbs more). The instructions are identical. The prices are different.
They've got a decent sale right now and I think it's time for me to get a roof rack so I was going to order one this weekend but I've got no idea if the extra money is worth it for the heavier roof rack or not.
The primary difference between the ⁠RCI Offroad Horizon and Ascent roof rack lines for the Toyota Tacoma is the material and style of the crossbars used: the Horizon series utilizes slotted steel crossmembers, while the Ascent series upgrades to extruded aluminum T-slot crossbars.
Thank you!!
On the website both of the descriptions say they use aluminum t slot cross bars so it was a bit confusing. The text is literally a copy paste between the two.
Take that with a grain of salt, I dropped your headline into a Google search😉
Oh okay then 🤣
I can't find anyone with actual photos of the two different racks. Or videos. It's all the one rack.
I would call them and let them know that someone got lazy when dropping in the description and find out from the source.
I sent them an email this morning but since it's the weekend I probably won't hear back until Monday when the sale probably will be over 😂
In the past I've had good email exchanges with them when I had product support questions. All of my skid plates and sliders are from RCI and they've held up to some significant abuse.
Runnin on E
Wincher
Outside
"All of my skid plates and sliders are from RCI and they've held up to some significant abuse."
X2
For future reference, Marco at RCI sent me this info. I decided to go with the Ascent version. I've worked with aluminum t slot framing for almost 30 years now and I find it to be nice to work with. Also I want to minimize steel on my roof due to where I live (salt air).
Hey there,
Great question! Here’s a quick and simple way to break down the differences between our roof rack options:
Ascent Roof Rack
Best if you want maximum flexibility:
  • 360° T-slot crossbars (easy to move and adjust)
  • “Drop-in” bar capability for quick setup changes
  • All-aluminum construction (lightweight + rust-proof)
  • Ideal if you’re frequently changing your gear setup
Horizon Roof Rack
Best if you want simplicity and value:
  • Fixed-position steel crossbars (strong and stable)
  • More “set it and forget it” design
  • Higher rigidity for heavier, constant setups
  • More budget-friendly option
Bottom line:
  • Go Ascent if you like to change or fine-tune your setup often
  • Go Horizon if you want a strong, simple rack you can leave set up full-time
Both options use the same mounting points and share the same overall footprint, so it really comes down to how you plan to use it.
I hope this helps! Let us know if you want help deciding based on your setup!
