• AUGUST 2026 CLUB MEETING: NEW LOCATION + EARLY START TIME
    Hi Guest: The next RS meeting will be Wednesday, Aug. 5, 2026 at Fairmount Park in Golden.
    • Location: the August meeting will be held outdoors at Fairmount Park in Golden.
IH8RUST: FJ60
IH8RUST
Went out of my way to park there.
IH8RUST
Skirt bolts. Next, waiting for the flange bolts to replace the outer ones.
PS. I've discovered the arrow shape in the Photos app of iOS. Expect more arrows in subsequent pics.
IH8RUST
Maybe don’t sell parts that aren’t correctly measured, just a thought and I’m absolutely not amused. Kinda pissed off that I’ve spent money on an inferior product design.
justcruisin
Wincher
Aurora, CO
...and for that price I would expect absolute perfection too. Arghhh.
IH8RUST
I just got off the phone with him. I'm annoyed that I have to go out of my way to fix something that was meant to be bolt-on, so I'll ask someone local to relocate the latch, tig weld, then send it back to their shop for re-powder coating. He's nice enough to reimburse the cost. I get that there is a QC issue, but I don't want to be part of that convo.
@timmbuck2 told me to get my act together and finish the rig so I can join them on the 60 run, project planning all the interior work now, trying to figure out headliner color since I get one shot at it.
Meanwhile, found the grommets for the rocker panel. Also, those holes, they need plugs. Before I plugged them, I used the compressor to blow out stuff, about 10lbs of sandblast media. Very important things.
Installed the driver's side quarter panel emblem.
I should get those grommets. Since that area is rust prone, I sprayed a bunch of fluid film in mine when I did the interior of the frame.
IH8RUST
Plugging some holes. I don’t know if I got them all correct, but they fit. The skirt is pretty decent, don’t recall if the skirt flange bolt needs a washer or not.
IH8RUST
I never returned the equipment, and I'm glad I didn’t. Took the time to strip their coating, media blasted it. Prebaked it to 100 degrees, then powder, and finally, baked it till it reached 400 for 40 minutes, just pulled it. So far, it looks like it might have worked.
IH8RUST
Had to redo the top bolts, used my old ones. Filed down the bolt holes to make things work. Good as new.
IH8RUST
It turns out, I wasn’t done here. Took the hardware off, sandblast, powder coat. Way more durable.
IH8RUST
This is what ADHD is like: Not happy with the bench, repaint it, but smoke cigar first, sandblast, wire wheel grind, smoke cigar, scrub, scrub, grind, found rust, derust, smoke cigar, powder coat, bake, cigar, online browsing, zinc plate, pull the new altnator pully, mix chassis black 2K, clean paint gun, repaint, smoke cigar, get high off the fumes, go grill a steak.
IH8RUST
New reman (60v) alternator from TPI is in. Of course I took the time to plate the fan. The V-belt tension feels right, can bend it 90-degrees, push it down about 1/4 to 1/2 an inch. Charge light comes on with key on ACC, goes off on ignition, belt is dancing no mo.
Can someone verify if it looks OK running?
