I ended up using wire brush to clean the connectors while I have it pulled out!The connector contacts often oxidize causing the cluster to become a cluster. As you know there are many pins and mating sockets. Mine was acting up and a careful cleaning with de-ox it and mild abrasive fixed it. Worth a try.
Looks perfect! Beautiful work, Will.
I want to start smoking again just to use a freshly zinc coated ashtray.
Damn that 60 is looking good!
