IH8RUST: FJ60
IH8RUST
Going to the cluster gauge, I got voltage on the harness. Oh god, I think it’s the cluster gauge.
RDub
Boulder, CO
The connector contacts often oxidize causing the cluster to become a cluster. As you know there are many pins and mating sockets. Mine was acting up and a careful cleaning with de-ox it and mild abrasive fixed it. Worth a try.
IH8RUST
I ended up using wire brush to clean the connectors while I have it pulled out!
IH8RUST
Sitrep, I'm tired.
Went down the usual rabbit holes first: replaced the dimmer rheostat, replaced the headlight switch, pulled the cluster, and inspected the printed circuit (traces were fine). Meter read ~12V everywhere, so I kept chasing "where's the power going?" That was the trap.
What actually cracked it:
  • A DMM will happily show 12V through a dead or high-resistance connection because it draws almost no current. Switched to using an LED as a load tester, and that told the truth: power was real all the way up to the cluster.
  • The HVAC illumination was dead too, which meant it wasn't the cluster.
  • Turns out it was the GROUND, not power. On these, the panel illumination grounds back through the dimmer. The bulbs had +12V the whole time; they just had no path to ground. Touching the bulb-return pin to bare metal instantly lit the whole dash. Ugh.
Root cause: bad/intermittent ground at the dimmer connector. I'm still unclear why this is happening now. The kicker: the factory rheostat barely dims LEDs anyway, so it was never doing much. I'm trying to convince myself of that much.
I have a couple of fixes in mind:
  • Free version: bypass the dimmer and permanently bond the bulb-return wire to the ground wire (solder + heat-shrink). Dash and HVAC come on full bright every time. Yay (?)
  • I still want dimming back with LEDs? Need to find a high-side PWM dimmer, but then I have to figure out how to house and mount it with OEM. Breaks my heart not having the knob, so I want to see if I can hack something together.
And for my lesson of the day:
  • "Works, then doesn't, same steps" = an intermittent connection, every time.
  • Don't trust meter voltage on a loose wire; load-test with an LED or test light.
  • Sort out whether it's a power OR ground problem before swapping parts. Giving the circuit its own ground during testing can mask a faulty factory ground.
  • Stock rheostats don't dim LEDs, go PWM/high-side. I still don't fully understand why the F the whole thing worked before, and now it doesn't.
IH8RUST
Before.
Since I have it out, wet sanded with 5000-10000, then used the Chemical Guys V38 with a wool pad to polish the glass. It buffed out most of the hairline scratches, gave it a nice clear shine.
Going to attempt to paint the bezel, waiting on the paint to arrive.
IH8RUST
I don't know why, but I hadn't even given the vapor barrier a thought until I was watching this guy's latest episode, and BAM, vapor barrier. Need to find something for the doors.
IH8RUST
The tiniest grommets to get the scoops back on there. Why it had to be different than all others remains a mystery to me.
IH8RUST
Thanks, Sam! Came out pretty good for two hours of work, and most of that was masking the part.
  • Gave the ashtrays the zinc coating treatment before I sent them off to Branden D. for the door cards. He does good work.
  • Finished the frontend, replaced all the old bolts with new ones.
  • Redid the connectors for the markers with the Sumitomo; now they're nice and sealed. Old wires were short; I did some splicing and saudering to extend them. On that note, LSWiring has near identical colors and gauges. I might just have to take a stab at redoing the rear harness someday.
  • Repainted the ventilation in the cabin; it was wet when I took the picture, but it looks fantastic now.
KC Masterpiece
I want to start smoking again just to use a freshly zinc coated ashtray.
Damn that 60 is looking good!
Not sure if you posted on them but care to share info on those sweet battery terminals?
