Parts to order
- Toyota Radiator Cap (Toyota OEM PN: 16401-15210)
- Toyota Upper Hose (Toyota OEM PN: 16571-66030)
- Toyota Lower Hose1 (Toyota OEM PN: 16573-66010)
- Toyota Lower Hose2 (Toyota OEM PN: 16572-66021)
- Toyota Heater Control Valve (Toyota OEM PN: 87240-60140)
- CRC Thermocure Coolant System Rust Remover
- Foam around the radiator -- need to figure out what to use
- 1FZ-FE Engine Little Hose Kit - available from Wit's End
- Water Pump (Toyota OEM PN:16100-69325) - mine is working fine with no leaks but should I replace anyway?
- Toyota Thermostat (Toyota PN: 90916-03117)
- Toyota Thermostat O-Ring (Toyota OEM PN: 16346-66020)
- Connections to the rear heater under the cab - need to check these (I still have the rear heater)
- oil pump gasket - not leaking
- front main seal - not leaking
- oil pump o ring
- oil pump torx head screw replacements
