1982 Toyota RN48 SR5 Long Bed thread
original Gray or current Blue
  • gray
    Votes: 17 94.4%
  • blue
    Votes: 1 5.6%
  • Total voters
    18
I am going to fix it
they’re all the same that i have seen
it’s a poor design rust factory made in the usa
You got the skills, can't wait to see it when you're done! I have a Stout cab that needs some magic too... also rust factory
Did you see this article? Interesting read! :)
Toyota Truck bed factory
i did see that article!
interesting read..
if only one could use a time machine and roll up to the door and drive off with one of them beds from the stack!
i did finally get this side down as far as it needs to go,
so now it’s more clear in my head what the process will be to put it back together
finally got a few hours in the garage
made some progress putting metal back in place of the holes
i bought this bed blank from canada
i then discovered the side pieces that run from the well to the tail end have two ribs that are different than the bed and the wheel hump has yet a third rib profile
so i decided to cut out the two different ribs and replace them with the bed ones
this requires “terminated” ends to the ribs
so i did that by hand
also got the wheel well partially done
i had to pizza slice it to make the round and then convex
but it will be fine
i left some extra metal on the rib panel until i can measure out what needs to happen where the well meets the floor layers
i will then have to “terminated” all these rib ends as well like the above two
i think i am going to end the floor ribs right at that line which will catch the bed support mount holes and the put flat in to meet the wells which is how it was from the factory near as i can tell
got a few more hours in today.
I need to get the floor where it will live back attached to the cross members before making the patch that joins the wheel tub to the floor.
so i started there
since I changed the profile of the outermost floor the rear crossmember attachment point was off
so I fixed that first cutting the square nut off welding the hole closed, drilling a new one in the right place and moving the square nut inboard over the new hole
after
i also finished welding in this panel in after i had a bolt in that to hold the floor proper flat like against the crossmember
the next step was to put the “front rear” cross member hunk back in place I had cut out to get to all the rusty bits
this one has a sandwich of metal on the outer part of the crossmember to add strength.
as with most things that are two pieces of metal sandwiched together with some spot welds that live under a truck, it was crusty between the layers and it bothered me.
so i separated the two layers and made a new scab plate to put back in.
this time i seem welded all round the new piece and spot welded to slow the intrusion of water and also left one open hole on the bottom so if water does ingress somewhere it has at least a fighting chance to egress its ass
i am now less bothered
after that i just cleaned up some of the welds and put a couple boring flat patches in so i can get this crossmember chunk welded back in and then the floor secured in the right plane.
that will dictate the extended of the curve on the patch coming off the wheel tub
glad to be done with all the “ribbed” patches those sucked because nothing was exactly right from the patch panel i bought and required a lot of panel beating
i am glad i thought ahead and made this 3 point reference jig so I can get the crossmember out back together true because there are two bed mounts involved in that 3 point jig so it needs to be right before i weld it back together
then i can put the truss-head bolts in the floor through that cross member and THEN finally be able to get the profile right for that last patch
this was my stopping point
I am SLOW at this and getting SLOWER 😂
few more hours in the garage
the hard part is done on this side
a little more quality time with a flap disk and finger sander and hammer then i can move on to the body panel patches which should be easier than this floor and well
glad this part is done.
i went from “this is too hard” to “eh this will be easy” to “just kidding this is hard” lol
then rinse and repeat on the other side which isn’t as bad as this side
Love seeing all that new metal! Keep up the good work! I need this motivation as I just cut rear sill out of my 40.
so apparently it’s been 5 months since i touched this truck sheesh
got two hours to work on it
so i got the bed bottom ready to put the cross brace back in
then fitted the bed side patch on this side
baby steps is all i got time for
