72’ FJ40 Cruise Moab or Bust. Bust Maybe Next Year.
rckhound
Durango, CO
Ok so the 72’ I am picking up tomorrow I have decided to try and get it road worthy enough in the next month to drive it out to Cruise Moab probably Friday night and meet up with you all. Lots of unknowns still but things I do know need to happen include:
Flip Bezel
Fix fuel system- pump is bad and carb needs a rebuild.
Replace brand new rotten tires with lessor rotten tires.
Fix everything electrical because not much works. Probably just needs connections cleaned.
Replace battery cables because they are opposite colors currently (anti theft)
Replace tie rod, relay rod, drag link, plus all ends- they are all bent and in rough shape.
Replace all rubber brake lines because the are falling apart and go through rest of brake system.
Fix windows because regulators are worn and glass wont close all the way. May just go doorless for now.
Go through cooling system when running and replace hoses as needed.
Replace orange death fan with new plastic.
Put new wipers on because it always snows or rains on the way.
Go through ignition system carry some extra points and condenser.
Change every fluid and every filter.
Install winch if I have time.
Removed diamond plate and fender flares- this will probably happen within the first hour of ownership.
Make a functional speedo and gauges so I can tell temp and oil pressure.
Clean gas tank.
Rebuild parking brake.
Clean everything because its filthy.
Pray for decent weather so its not all done with sideways snow.
Drive slowly to Moab and drink beer with friends around a camp fire.
rckhound
Durango, CO
It begins. The Orange death fan is the factory steel radiator fan that eventually fail from metal fatigue and try and exit through the shroud and hood. I had one that the shroud was ripped open and had a hole in the hood from a failure. So now I put a later plastic fan on when I encounter them.
rckhound
Durango, CO
New car in a can doing its thing. Its always nice to see the color come back. Flare removal in progress and they must have run some wide tires at some point because both rear fenders were bent from impact.
Took me 12 months to do everything you listed, so you'll probably get it done in time for CM!
rckhound
Durango, CO
Well weather has not cooperated yet. Lots of cold and sideways blowing snow. I cant wait to hear it run!
rckhound
Durango, CO
Mild easy progress amongst the snow today. Front wheel bearings are loose and with probably rebuild the front knuckles when I have a warmer weekend day. Both rear brake drums about fell off so have some adjusting to do with the braking system forsure. Also got the other side diamond plate off and its just as rusty as the other side. Hope to keep making progress but looks like snow almost all next week. Love me some steel wheels and hub caps.
rckhound
Durango, CO
Well got the tire carrier on but latches are pretty worn out so may need to order some replacements. The latching mechanism is still available new and there are a couple people
making repop catches. Good news is I got the fuel pump replaced but the gas in the truck is real bad. Was able to run it off pouring gas in the carb and it looks to have good oil pressure and sounds healthy. Pulled the carb off and will rebuild it likely tonight. The stupid poly tank doesnt have a drain plug so I think ill have to pull it to clean it. Ill probably replace all the fuel lines as they are full of gunk. Got the new brake lines in the afternoon and got the system all cleaned out and bled up. Progress! Was awesome to hear it run.
Old40Dog
Hope to see you in your 40 in Moab! Will be there!
rckhound
Durango, CO
More single digit mornings and cold days keep progress slow. Little updates.
Rebuilt the carb at the kitchen table and its dialed. One of the dirtiest I have seen in awhile. Tons of passages clogged.
Ordered lots and lots of small parts and a actually splurged for a new OEM fuel tank 77100-60012 Sender 83320-35020 Gasket 83361-20020 and hardware 93319-14010. Ill need to get rid of my charcoal canister and evap stuff but I dont have to worry about emissions up here.
Learned that the Header on the truck is a smog legal California spec Downey header which is kinda cool.
After dealing with dirty fuel systems in the past I have just decided to replace everything in the fuel system from tank to hard lines.
One thing I am pondering is converting from a vacuum retard distributor to a vacuum advance distributor because I have a new OEM one on the shelf loaded with a petronix unit. This would entail porting the factory carb for the vacuum advance. Anyone have luck with this?
rckhound
Durango, CO
Parts NeedsSupplierPart Numbers
Side StepsToyota51707-69015
Fuel PumpToyota23100-61011
Front BumperToyota52111-60030
Fuel filterToyota23030-24011 X 2
Plug WiresNGK8149
Oil PumpAisinOPT017
Window Channel RubberToyota68213-90300 x 2
Window Channel WeatherstripSummit RacingPrecision GRB 5110 64 x4
Brakes Line Braided BTBBTB
Carb Rebuild KitCruiserTeqCARB60145
Interior
Master Cylinder
Carb Gasket BaseCruiserTeqCARB60010
Carb Gasket Heat RiserCruiserTeqCARB60011
Shift KnobToyota33504-60020
Hub Cap FrontToyota42621-60010 X 2
Hub Cap RearToyota42621-60020 X 3
Lug NutCruiserTeqWHL01007AFT x 27
Back Up LightToyota81670-60030
Toyota EmblemToyota75450-60021
4wd EmblemToyota75453-60012
FastenersToyota90179-04092 x4
Fill PlugToyota90341-18049 x 2
Drain plugToyota33104-30011 x 2
GasketToyota12157-10010 X 8
Fill PlugToyota90341-18002 X 2
Drain PlugToyota90341-18057 x 2
Gas TankToyota77100-60012
Drag Link at PitmanCruiserTeqST45442
Tie Rod End KitCruiserTeqTRE69045
Japanese Drag LinkCruiserTeqTRET60010JP
Japanese Relay RodCruiserTeqTRET60040JP
Japanese Tie RodCruiserTeqTRET60021JP
Defrost DuctAutozoneDorman 96004
Door HandlesTerry Rising Sun
Fuel SenderToyota83320-35020
Fuel Sender HardwareToyota93319-14010
Fuel Sender GasketToyota83361-20020
Eblem Gasket toyotaToyota75462-60010
Eblem Gasket 4wdToyota75463-60010
Eblem PartToyota75312-60020
Wiper BladeToyota85220-60030 x 2
License Plate LightToyota81270-60020
Gas CapToyota77310-60090
side loops64921-60010 x 6
side loops64921-90310 x 4
side loops boltsToyota90150-40002 x 16
side loops nutsToyota94115-40400 x 16
swing out cushionUsed-Ebay51907-90300
headlight switchToyota84110-60030
wiper switchToyota84650-60050
drain plug gasketToyota90430-25013
BeltToyota99523-11046
Distributer clampToyota19905-40010
Distributer RotorToyota19102-45060
Hard Fuel LineAmazon Stop Shop5/16"
Oil Walmart 15W-40
FilterNapa1515
Steering Column Dust BootToyota55122-60021
Battery Tie DownToyota in Inventory74404-60030
Wheels and TiresFactory in Inventory
Gear OilNapa80W-90
DistrubutorCity Racer
PaintCruiser CorpsRustic Green
Pump Side Rad HoseToyota90916-01056
Rad Side Rad HoseToyota90916-01058
Inlet Hose Toyota16571-60060
Bypass HoseToyota16261-60011
ClampToyota90460-50016
ClampToyota90460-58013 x 3
ClampToyota90460-49062 x 2
ClampToyota96112-10330 x 2
T StatToyota90916-03012
T Stat Housing GasketToyota16341-60020
T Stat GasketToyota90430-40058
Clamp Heater HosesToyota96112-10250 x 8
Latch swing outToyota69350-60010
Tcase shifter BootToyota58280-60020
Headlight assemblysToyota81110-60P70
Fuse Box CoverCity Racer
Vent DrainsCity Racer
Vent Drain GasketsCity Racer
Outter Window GasketCity Racer
Rubber Heater DuctCruiser Corps500-152
High Heat Header PaintNapa
Air FilterNapa
Clear Coat PaintWalmart
AlternatorNapaRay 213-8014
Fuel LineNapa5/16ths
Heater Hose Bulk Napa5/8ths
AntifreezeWalmart
Wheels StudNapa
PointsNapa
CondensorNapa
Winch PlateCCOT
Bolt KitCCOT
Fitting for TankCCOT
Oil LinesRed Line Landcruisers
Spark PlugsNapaNGK1233
2F core MotorBrianJune 1986
Oil PanToyota62101-11013
Desmog kitTLC Performance
Head RebuildGunn
Block RebuildGunn$200 deposit
Cam/LiftersDelta
2F Gasket SetToyota04111-61044
PistonsToyota13103-61011
rod bearingsToyota13204-60011
Freeze PlugsToyota96411-42500 x 4
Freeze PlugsToyota96411-45000 x 5
8 blade fanRock AutoFNT017
OME deluxe lift kitCruiser Outfitters
Cam BearingsPartsouq TaihoC031A025
Piston RingsPartsouq TP358363F050
Cam PlugPartsouq Toyota90331-48010
Water Pump AisinRock AutoWPT028
Water PumpCity Racer
FYI This is how I keep track of what I am working on. Hopefully part numbers can help someone else. FYI this is for a 10/71 build 1972 FJ40. There are some weird year splits on parts.
I bought a new OEM tank maybe in 2008 or so. And then 10 years later I pulled it out to refresh some things, and the bottom was already rusting. I POR-15'd it and stuck it back in. I expect having the abrasion protection of the POR will keep the tank good and healthy for a long time to come. You may consider doing it before slapping it in.
rckhound
Durango, CO
Did you replace the factory tank pads when you put the new tank in so it didnt sit on metal?
I cleaned them up and put them back in, yes.
I sent one to Jim C awhile back. Turned out great but expensive. Did another recently and had a friend with a machinists drill press do it for beer, also turned out great. Just needed to find the right size brass tube for the line. Seems easy if you have the right tools and have one to compare to.
