FJ55 tail light seal made of Ninjaflex:
Hmmm, that is exciting. How are the lens gaskets? Pretty flexible?
Any clearer options on lenses? How about Amber/Red?
Jeff, Have you tried to sand and polish the lenses? I wonder if that'd work.
Super cool that you're using additive mfg for making cruiser parts. way cool.
Very cool!
My pinion seal was leaking so I replaced it. I couldn't get a regular seal driver to work because the pinion was in the way, so I used a hub socket. I ended up driving it in crooked and it is still leaking!
So I designed and built an SST specially made for driving in the pinion seal while the pinion is still sticking out. This one is made of Taulman 3D's Bridge nylon, which has a tensile strength of about 4,800 pounds.
looks like that might work for the front crank seal on an 80? or too long to fit between the rad & block? I 'm a fan regardless.
