American 3D Printing Cruiser Parts
FJ55 tail light seal made of Ninjaflex:
Hmmm, that is exciting. How are the lens gaskets? Pretty flexible?
Yes, 85 durometer, shore A. Not quite as flexible as natural rubber, but pretty close.
Any clearer options on lenses? How about Amber/Red?
Yes, that was translucent ABS, we're going to try a build with PET (that's the plastic they make water bottles and soda bottle out of). Building with PET is way slower than ABS, 30mm/sec vs. 90mm/sec.
Yes on the amber and red, but only in PLA (Poly Lactic Acid), which isn't as weather resistant as ABS or PET and therefore must be clearcoated with urethane or lacquer for outdoor applications.
We're currently designing pig grill front marker lights for TJ Scholand of Horsetooth Landcruisers, they will be amber.
Note that the above parts are being designed and produced for John Russo, AKA SLOCRUISERs and can be purchased from him on his web site once he gets into production on them.
Jeff, Have you tried to sand and polish the lenses? I wonder if that'd work.
Super cool that you're using additive mfg for making cruiser parts. way cool.
cruiseroutfit
Wasatch Cruisers
Sandy, UT
x2, I wonder if a sand and clear coat with smooth them up a bit and help mellow out the color/texture.
My 1971 FJ40 had a disintegrated defroster duct. I got some replacement hose from a guy on Mud who was selling it as a replacement hose for FJ60 air cleaner hose. The ends where the hose attaches to the rig were cracked and dry rotted, so we built new ends out of Ninjaflex. Fits like a glove!
Here are some backup sensor adapters we made for Christo. They are made out of the rubber-like Ninjaflex.
This is a replacement fuel sender gasket for a 40. The Ninjaflex is made out of TPU (Thermoplastic Urethane) elastomer. It resists aromatic hydrocarbons like gasoline but will last far longer than the natural rubber one it is replacing.
My pinion seal was leaking so I replaced it. I couldn't get a regular seal driver to work because the pinion was in the way, so I used a hub socket. I ended up driving it in crooked and it is still leaking! :mad::rant:
So I designed and built an SST specially made for driving in the pinion seal while the pinion is still sticking out. This one is made of Taulman 3D's Bridge nylon, which has a tensile strength of about 4,800 pounds.
DanS
Dumont
That is slick!
Much nicer than the one I made out of a 2x4 with a hole in it.
Dan
Lastresort576
looks like that might work for the front crank seal on an 80? or too long to fit between the rad & block? I 'm a fan regardless.
I don't know about an 80 but I know on my 40s and 60 there's no way without pulling the radiator to pull the crank pulley off anyway. On a 40, it's pretty easy to use a seal driver on it because it has to go in the back side of the timing gear cover so you have to take the timing gear cover off anyway.
