Adding receiver hitch to popup camper for motorcycle hauling
And there ya go. I bet a boat trailer can be had cheep.
Now that looks like a much better solution than fabbing your own trailer frame.
Beater
denver
So why not buy that? A whole lot less effort and if it sucks, sell it off.
to quote directly...
[FONT=&quot]Too gross. Please take our current pop up to a shop that enhances campers for a living.[/FONT]
:lmao:
:lmao:
Yeah... good luck with that. They will enhance it with anything from the catalog and sorta install it. You better get nose surgery to pay a fabricator to build it for you.
Just because the example is... um... inexpertly executed, doesn't mean the basic idea is worthless...
But in our case we have history with the older, gross camper. And therein lies the difference, I suspect.
Beater
denver
back away tim, back away.
lol
I just had a repeater trailer flashback. :)
Build a new frame for your existing camper. Build a receiver into the back of it for a two bike mount. Then place a water or fuel storage system on the tongue for an adjustable weight bias to keep your tongue weight in line. Something as simple as 6 or 8 scepter/jerry can holder. Fill what you need when you need it. You can remove them to lift it off the ball when solo.
NakBallast system!
I like the thought. Was thinking more along the lines of what Corbet said- have a small shelf and receiver in back, then just shift cargo accordingly. But the dual water tank with self-adjusting pump does sound like a trick mod though. Though how much water do I really need to carry? 1 7 gallon jug seems to last us the weekend.
What would be even cooler would be more essential cargo attached to a movable tray, beneath the camper. 2 batteries, 2 propanes, jack, the spare tire, generator.. all on a movable slide supported by two tracks inside the frame rails, and a big lead screw that moves it as far forward as under the tongue deck (also for access), and as far back as right next to the axle. Probably 200 pounds of stuff you wanted to carry anyway. So instead of a pump with 2 tanks of water, it's just a motor turning a threaded shaft.. and you could have some type of auto/manual/off switch to control the thing.
edit: you could also do a second tray behind the axle, tied into the same motion. it hits the forward limit with the forward tray is under the deck, and its rear limit is against the back bumper, when the forward tray hits the axle. I wonder if 3' of movement is enough to get the adjustment you want, that's likely the limit here. :confused:
water is heavy.. why would you want to always haul it around?
Water weighs 8 lbs per gallon or 64 lbs per cubic foot from memory. So you'll need to do the math on how much depending on distance from the axle to counter balance the bikes. If you drink all your ballast I'll refer you to this thread for the solution: http://www.risingsun4x4club.org/forum2/showthread.php?t=17825&page=4
Dave will know where I'm going with this and can adjust his idea accordingly :p:
