AxleIke
No those filters work awesome. I’ve used it with galvanized, grinding, etc. nary an issue. It fits better under the helmet in my opinion (both my Miller pro hobby and my Lincoln Viking).
I believe the yellow means it's zinc-chromate, which gets you both the zinc and the chromate toxicity so you're doubling your chance to get metal fume illness! I'm too old to worry about being cool so I always wear a respirator when grinding and welding. I have the 3M pancake P100 masks that fit OK under my hoods.
And for stick welding I'd definitely wear a mask, the flux burning off just stinks anyway.
Yeah Isaac and I are probably overly OCD about it but do keep a little notebook to jot down settings. It's less frustrating to at least give yourself a starting point when you change between metal types and thickness and stuff.
slightly derailing the thread...
I should have prefaced my comment with the fact that I have about 5 hours of total time welding and have never used a filter system. My experience comes from my environmental work and overseeing abatement projects where people were torching cast iron to remove asbestos from a power plant's generators. They used a combo filter with the back snorkel attached to a Scott fullface. I used a powered full face with combo filters.3M told me to use 2097 or 2297 (the difference being the 2297 has longer useful life and resilience to damage) for all types of welding including stainless.
https://multimedia.3m.com/mws/media/5188O/3m-particulate-filter-2097-p100.pdf
Could it be that they are just the highest level that fit on the masks and under the helmet? To get a yellow/magenta would be the full size 60923 cartridge and those wouldn't fit under my welding helmet. Does that fit under yours? Perhaps they are assuming the ventilation reduces fumes to nuisance level. Not sure to tell the truth.
Indeed, having a supplied air or powered air is better.I should have prefaced my comment with the fact that I have about 5 hours of total time welding and have never used a filter system. My experience comes from my environmental work and overseeing abatement projects where people were torching cast iron to remove asbestos from a power plant's generators. They used a combo filter with the back snorkel attached to a Scott fullface. I used a powered full face with combo filters.
If a particulate is your concern then the p100 will offer the best protection. If your concerned with gasses then you need to have something with activated carbon to absorb the gasses.
Correction... the best protection is scba (self contained breathing apparatus). P100 is the best filter for particulates.
Wow, that thing is hella beefy.
You're double diamonds make me very happy so you must be ecstatic! So nice man!
yea it’s either 1/4” or 3/8” tube. Can’t remember off hand.
Looks good man. Drawers next?
