My names Terry, I run a bodyshop in Northglenn and Bill has brought me his truck and a donor body and frame. I'll be doing some repairs on the donor body as well as swapping it over to Bill's frame. A complete repaint will be done and Bill's rig will be back as good as ever.
Some of you may have heard of my rig The Xota, I am the crazy guy that put a 4.0ltr Jeep Engine and a XJ front clip on a Toyota cab and modified frame. I don't think Bill knew that when he first considered me for this project, and it's too late now.
I'll try to keep the pic's coming as we go thru this body swap
This morning I got the donor body unbolted from the frame
I started looking the body over and Bill and I were already aware of a couple of rust spots on the left body side.
As is usually the case with rust repairs, there's more under the surface than you can usually see from the outside. In this case the rust is not too bad, but the quarter has been repaired before, you can see a couple of spots where I ground thru the paint and the pink stuff underneath is body filler. To repair it properly, all the old bondo should be ground off to bare metal.
This rust spot is further back on the quarter and even thought it's bigger, it should be easier to repair since there isn't bondo all around it.
