Thanks Gary
I will ponder this some more.
- You should bring those to the next meeting
The snorkel has done an awesome job in lowering the intake temps by 20 degrees at least on a hot day.
I'm not sure I buy that... How was that measured pre and post snorkel install. Or are you just measuring the temp at the snorkel inlet and old intake inlet?
His data prolly came from his OBDII reader, which would be reading the data stream from the mass air sensor.
Thanks.. I guess I believe now![]()
). $20 on fleabay, eh? Stinker.Romer,
Here is what you need to do...get some yarn and tape (blue painters tape). Cut the yarn into 2-3" long pieces and tape them to the hood in strategic places. Then go for some test drives and see how the wind flow affects the yarn (i.e. flowing straight back, going all over the place, etc.)
I know it sounds stupid/silly but it should give you an idea of the general flow of air across the hood as YOUR LX is setup now with the ARB etc.
So if I do this what should I be looking for relative to consideratiuon of a scoop? If it's flowing straight back at that location is the correct thing to look for I would assume.
Again, I am not trying to lower intake as the Snorkel already does that. Just want to lower underhood temps 5-10 deg F on a hot day while driving. I know it won't do anything going slow or standing still.
. I know you stated you weren't looking to lower you IA temps as the snorkle is doing that but in my brain under hood temps and IA temps seem to sort of go hand in hand. If you can lower your under hood temps then the IA temp should also drop.
Yeah... and you are still getting passed!Cool test!
I like that your camerawoman is calling out "70, 75, 80" as you're passing 55mph signs!![]()
let me know when you get your hood cut. I want to do mine the same day. I have just been sitting back waiting for the final word...
