how many miles are on the engine?
have you verified the timing is doing what you think it is with a light?
Ok, I'm just curious![]()
I presume you have carefully inspected the inside of the distributor cap for carbon trails and/or cracks? Same with the rotor.
Hmmmm.. well ok, thats good info. Was the truck doing the weirdness at the time?
What do the o2 readings do when it is showing the issue? also when it'
s down on power it is running smoothly just down on power or is it running rough?
