This is going to be loooong, but to put it into some perspective I have been trying to figure this out for close to 2 years now.
I picked up a '93 and it is my first foray into Toyota's. Not knowing what to expect power wise (it had 315's on it when I bought it), I was not too underwhelmed with it. Until I had to get it smog'd and spent a few months doing some maintenance and with each phase noticed it was running better and better. It finally passed and then I just settled in and drove it. Until two summers ago I was driving home from getting a hair cut and went to pull away from a light and it just stumbled, no power at all, but it would idle fine. Then just as randomly as it stumbled, it came back to life and I drove home.
Since that day, I have wanted to drive it off a cliff more than I have loved it.
I limped it along the rest of that summer. Then fall and winter set in and it started running like a champ again. Pretty much forced the issues out of my forethought and continued on with life. Fast forward to spring and summer, and the issue is back. I finally came across a thread on 'mud about non-Toyota Denso fuel pumps actually drawing more amperage than the Toyota labeled ones. I had replaced the fuel pump with a Denso labeled one as part of PM. I ordered up a Toyota one, swapped it and that seemed to have fixed my problem. At least the complete and total loss of power problem.
Fast forward to present day and the issue I have now is that some times it massively down on power. Think e-brake on and trying to pull a trailer down on power. Right on the verge of being a road hazard down on power. I have a TOYOBD1 reader and nothing shows out of the norm (at least to me). And just like the stumbling issue, some times I will hop in it and she'll run like a scalded dog.
I have replaced a lot of parts in this process. Including, but probably not limited to:
I recently deleted the PAIR system and moved the O2 sensors to the manifolds. I also redid one of the harness connectors as it was majorly corroded. The O2 readings from TOYOBD1 appear to be within spec.
When I did the EGR I had the intake completely off, did plug seals and valve cover gasket as well. When I was in there I verified the wiring harness by the EGR pipe by checking continuity from the far end and ECU end of the harness.
I am really, really tired of trying to figure this out and could really use some help.
- ECU - Mine is an early 93 and had the 89661-60170, swapped it with a 89661-60221
- Injectors - Newer 4-hole 23209-66010 from a 1FZ powered 100/105-series
- EGR Valve and Modulator
- All vacuum hoses
- Plugs
- Plug wires
- Ignition Coil - 19080-66010
- ECT - 89422-35010
- Fuel Pump - 23221-66040
- Fuel Pump Relay - 28380-66010
- EFI Relay - 90987-02004
- Distributor Cap and Rotor
- PCV Valve
- O2 sensors
- Fuel Pressure Regulator
- Fuel filter
- Throttle Position Sensor
