Jesus Scott, that thing looks TALL.
Jesus Scott, that thing looks TALL.![]()
Thanks. Any no drastic lean? This question came up on MUD and I contacted David at Dobinsons for clarification. His reply was that they are installed correctly if there is no lean, and if there is lean they should be swapped. Not exactly the answer I was looking for.....I did.
I am not noticing a lean either and I installed them as labeled. My fronts and rears were both labeled right and left. I installed them in that orientation. I seem to remember measuring them while installing and the springs marked left were indeed a hair taller.I haven’t noticed a lean. Are you seeing it more in the front or back?
Were your fronts labeled? Mine weren’t so I had to call to confirm that the longer of the two was supposed to go on the left.
Interesting. I haven’t seen that thread but definitely know how crazy they can get.I am not noticing a lean either and I installed them as labeled. My fronts and rears were both labeled right and left. I installed them in that orientation. I seem to remember measuring them while installing and the springs marked left were indeed a hair taller.
There is a mud thread going on regarding this and I am sure you know how crazy those can get.
The question is should the be installed in reverse orientation like the OME springs?
I am loving mine so far. Don't feel the need for a whiteline in the rear yet but that may change.@KC Matsterpiece I installed my BIOR dual swingout bumper. The rear dropped an inch but there’s no lean. I ordered spacers for the rear to get things back to level and a whiteline rear swaybar to stabilize the ride.
How are you liking your setup?
Are you mostly noticing the noise when both sides compress at once? I.E speed bumps and dips? I'm debating if I want to pull the coils and try to modify the bump stops for clearance.Good to hear that you’re liking it! My bump stops are making contact with the inside of the springs and I had an intermittent groaning noise pop up after I corrected the caster with the radius arms. The DC driveshaft solved that issue.
@DanielChase This would be a great event for the Club to host. I don't have an 80 but would like to participate in this. Maybe we could do this at Slaughterhouse Gulch when the weather is decent and it's open?Sometime we should get a bunch of 80 owners together with all the different lifts and take turns driving each of them. I'm just curious how much different they are from one another. I've been running the Slee 4" lift on my 80 since 2008, and it's still going strong. I replaced all the OME shocks a few years ago.
Definitely down to do a front end flex test. Do you have a swaybar disconnect? If not I will be cheating.@KC Matsterpiece That looks really good! Now let's compare!
For weight I think we're probably about the same. I've got the Shortbus, winch and Labs, and carry tools and recovery daily and the fridge is still loaded. My tent is a little more centered on my rack. But basically I think we're similarly "unloaded trail ready".
In the rear I measure at 34" center to flare with the Dobs 3" VT (Heavy) coils. Which makes sense that you are measuring 33" with the 2" VT (Med) coils. Check.
In the front I measure 33.25" center to flare with the Dobs 3" Flexi. Which is dead on with your 2.5" VT measurement. Both of which are Med coils. Assuming the Fexi are true 3" I think my truck effectively compresses most of the "flexi" rate of the spring which makes me sag down .5" to match your measurement. Check.
It's worth noting here (and I'm sure you already noticed), in regards to the Front Dobs VT springs in general, that there seems to be some inconsistency with how the fronts are described. Some websites list the front VT C97-146VT as 2" and C97-144VT as 3" however the official measurement for the fronts are 2.5" and 3.5" respectively. Not sure why they do this but it creates a full misdirect for guys wanting to dial in these lifts. In regards to why Dobinsons stagger them this way @Lefty and I have scratched our heads and the best theory we can come up with is that they are designed .5" taller in front to account for a heavier diesel engine and heavier expo style bumper for those outback guys.
All in all it seems like you are also in that sweet spot between the 2.5~4. I'll be interested to know if you throw a spacer in the back of the 2" VT or jump to the 3" VT to level things out when you load up. The biggest test you and I need to conduct is a front end flex to compare the 3" Flexi with 2.5" VT. It'll be great to get these on the trail!
