KC Masterpiece
- Joined
- May 4, 2019
- Messages
- 1,319
Looking for some real world feedback from any Rising Sun members who have ran both a 2.5" and a 4" lift.
I currently have a OME setup. 851/860 Medium Duty. This was recommended to my by Christo when I first purchased the 80 2 years ago and wanted to get my 315's fitted. I was looking at purchasing their 4" setup but he indicated (correctly) that my truck was too light and performance would be subpar. The OME kit performed great until I started adding weight. It is now sagging significantly and the rear frequently bottoms out when carrying any kind of load on the trails.
My truck is currently unlocked. I was planning to get lockers installed before finalizing the suspension but so far the 80 has taken me everywhere my FJ Cruiser did with zero drama and no lockers. Nice to not hear the Atrac eating up brake pads anymore... I took the FJ up to Lake Como once and I think that is about the hardest trail I would want to run on a "camping" trip with the RTT up top. Thinking I may only lock the rear when I do a regear, but its hard to say no to the front when everything is torn down.... Back on topic....
Current Loadout
In the front I have a Trail Gear bumper with a 10k winch.
Rear has a 4x4 labs double swingout. Dobinsons drawer system. and a RTT. When camping we will load up the rear of the vehicle significantly with all sorts of goodies.
Currently I am sitting at around 21.75" front (hub center for flare) and 21.5" rear for daily driving. Rear drops to 21" or less when loaded, pretty close to stock height.
I have read through Slee's fantastic suspension guide as well as numerous threads on Mud. What I can't seem to find is a real world comparison of a 2.5" lift vs a 4". I am aware that getting into the 4" territory requires a good deal of additional work. SS brake lines are already on order to replace my current ones as PM since they have some rot in the rubber. Currently I am running with NO caster correction and it handles okay but I know I need to get on that. Planning to go with the delta arms regardless of lift height. Also aware that going beyond 3" puts me into possible DC front shaft territory. Living up in Silverthorne and using the 80 as a DD I have no desire to go to part time as I love the full time 4wd system.
I have settled on the Dobinsons tapered springs paired up with their shocks. They offer these in a 2.5" and 3.5" lift height, but it looks like real world results are closer to 3" and 4" respectively.
Now that my ramble is done.....
Does anyone here have feedback on a 2.5" vs 4" lift in real world handling scenarios? I have always been of the opinion that a suspension lift should be done with the following in mind.
Some photos using my patented lift height simulator. (two jackstands centered under the frame to get the wheel)
Thanks for the feedback. I gotta say.... 4" does looks good!
Current Loadout
- Fitment of tire size with no rubbing.
- Maximum articulation.
- Keep center of gravity as low as possible.
