Fishy
One of the biggest causes on the 100 is overfilling and then sloshing that fuel around. Once the pump shuts off, don't give it that extra splash of fuel.
I've always heard that once the charcoal gets wet, it will not dry out. However, I went about a year without filling up all the way and my problem is hardly noticeable anymore. I filled to about 3/4's or just above for a long time.
The 03+ 100 series has the shoebox-style canister (located above where the spare tire would sit). That vacuum valve goes bad too and the only way to replace it, is to replace the entire canister. $400+ if you can get a deal. $500+ if you're paying retail. I've seen gas literally squirting out of the cap on some vehicles. If you're going to purge it, go super slow. If you just open the cap all the way, you'll get the gas face for sure.
