Variety of things over the last few months:
Added 1in coil spacers to my dobinson 1.75s. I liked the height but after one outing, the spacers and coils seated wonky and I yanked them out for OME 850s.
I watched a Aussie YouTube vid about rebuilding the power steering reservoir and decided to try it. After disassembly, it was discovered that previous attempts to clean the filter without removal were inefficient and had actually damaged the screen from poking it with the red spray tube
I could not find a replacement filter or gasket so a few cans of brake cleaner later and the filter looked respectable. Put some rtv on the old gasket and buttoned it up.
Added a longer throw tcase shifter as I have had issues with it popping out of low range on the trail occasionally and thought that might help.
still having issues with an unhappy sounding power steering pump so in went a new unit. I just heated up the drive gear and used a brass drift to knock it off the old one. Unfortunately, the high pressure line died when removing it so that was replaced again too. Here's the old one
sweet jumping Jesus is bleeding the system a slow process
Added a toy Yoda to my Toyota. I have had this guy since 96 and I hope he brings me wisdom in line choice, navigation and leadership.
Raised the roller fairlead to match the opening in the bumper. The winch line had to cross a sharp edge and that needed to be fixed.Before and after pics
Tossed in some new OE tie rods as the 555s I put in were toast.
