Hi All,
I’ve never really done a highly technical write-up; so, I figured I’d give it a shot with my axle build.
I’m sick and tired of the lunchbox I have in the front end of my 60. I’m blaming it for my rebuilt steering gear and rebuilt pump that are starting to show signs of failure. My birfs have seen better days and I’ve also decided to make the step to a 315/75R16.
I’ve scored a set of FJ62 axles from the junkyard down in Littleton. I love it when regular old bone yards get Landcruisers (thanks Ricardo)…….it’s like Christmas. These axles will be my starting platform. I picked them both up as full assemblies for a tiny bit over $200 and some labor
(thanks to rockhound).
I chose the front FJ62 axle because of the added pinion angle built in. They both have 4:10’s in them. The front also has a truss built into it. Not sure how I feel about the truss yet, but I’m sure time will tell. As for now, it appears that it will be a good place to bang rocks into.
I know the knuckle rebuilds have been beaten to death, so I’ll try to focus on the R&P / ARB installs a little more. Hopefully someone will find it useful. ☺
I've set up a few 9" fords and a D44 back in the day. My experience is limited and I appreciate any constructive feed back. My diff setups and documentation will be reviewed by a good friend of mine (Brian Paul of Quick Performance) who has set up approximately 10,000 differentials all makes and models from mild to wild.
The plan:
Completely rebuild both axles flange to flange with detailed documentation here.
Clean, clean, clean, clean, Paint
Do a needed brake upgrade (I drove my truck around with 35’s for a weekend….scary)
Upgrade strength where I can
Lockers front and rear
Go from 3:70 to 4:10 gears
Do it all in my garage (with the help of a few stragglers and beer I’m sure)
Be done in plenty of time for Cruise Moab
Measure the Delta in pinion angles to understand how much reverse shimming I can do for caster correction.
The Parts:
• Front Axle
ARB locker
Longfield 30 spline shafts/birfs
Longfield hub parts
Reuse front R&P from fj62
Yukon (Koyo) master install kit w/solid spacer
ARP hardware
4Runner calipers new hardware
New hard lines (mine are mangled)
Marlin cross drilled and slotted rotors
Nice set of ceramic 4runner pads
Dust shield eliminator kit (both sets of shields that I have are pretty mangled….we’ll see about this mod, I’m a little cautious)
New pinion flange
New Studs
Paint (not sure what to use here. I used VHT epoxy paint on the housings/3rds last time and it didn’t hold up very well.) suggestions??
Bearings seals etc.
• Rear Axle
ARB Locker
Poly Performance Axles
New Toyota axle bearings and seals/gaskets
New 4:10 Nitro Gear R&P
Yukon (Koyo) master install kit w/ solid spacer
Turned drums (I now have several used pairs in good shape and can’t justify buying new ones)
New wheel cylinders and hardware
New shoes
New wheel studs
• Other Tid Bits:
4Runner Booster
Dakar add-a-Leaf for the driver side
315/75R16 Irock ND’s (this is their less aggressive version. From what I gather, they are supposed to be in the same class as a duratrack but ¾” skinnier on 8” rim)
Stand alone ARB compressor for lockers
Megan (my wife), Rockhound, and aprosise will likely be helping me document the process. With any luck I’ll be testing these things out on cliffhanger in late April and at Rubicon this August.
Expect to see the pics start flowing this week!!!!
Cheers.
The plan:
The Parts:
• Front Axle
ARB locker
Longfield hub parts
ARP hardware
New pinion flange
New Studs
Bearings seals etc.
• Rear Axle
ARB Locker
New shoes
New wheel studs
• Other Tid Bits:
4Runner Booster
Cheers.
