Already have a problem with the Sequoia I just bought.....
rushthezeppelin
Oh man I think my buddy was on to something. Pulled crank sensor and it fell right off the connector. Connector just wasn't clicked. Makes a ton of sense to as the PO mentioned that he has a problem with the oil pressure sensor where the connector holding it to the block was broken and it got into the belt. Crank sensor and oil sensor are on the same pigtail. He must have had to pull both to get the pigtail out and repair out and didn't click the crank sensor. Anyways she's up to temp and revving great. Still going to replace it likely as I did find a resource that said the spec was 895-1600 ohms and she tested 2300. Can someone confirm that for me?
rushthezeppelin
Hour test drive appears to have proven him out. Running fine now.
rushthezeppelin
Now that this is solved I need the procedure for readying the evap system done I had to clear codes.
rushthezeppelin
rushthezeppelin
Okay so if evap isn't ready is it still possible to pass? I seem to be reading that you can. They will just put her on the rollers right?
Squishy!
Littleton, CO
Yea you should be fine
rushthezeppelin
Well I'll be, evap literally cleared on the way to ACC.
AimCOTaco
Longmont, CO
Passed I bet?
Sounds like the new truck is happy, welcome to 2UZ life!
rushthezeppelin
Passed I bet?
Yup it passed. Truck is very happy now. These good numbers for a 2uz?
