rushthezeppelin
- Joined
- Oct 14, 2022
- Messages
- 1,167
Well drat already dealing with my first issue on the 03 Sequoia. So when I test drove the sequoia on Wednesday the owner was cool and let me floor it for a bit. I hit 4.5k and started getting some fluttering. I figured well maybe the governer is rather conservative on these engines (good ol Toyota undertuning). Even called a friend who has a 100 series and he confirmed that the governer kicks in somewhere around there. No other issues on the test drive and guy seemed like an honest family man who mostly works on his own vehicles and with this one had taken it in for timing belt and water pump as well as rebuilt the center diff lock actuator and replaced front diff actuator. He seemed rather excited to have a Toyota enthusiast own it and talked about how he originally had plans to build it into an overlander but decided to sell it when he got a bed camper and bought an f350 to haul that around. Basically everything checked out and the truck seemed super clean. Anways fast forward to Friday and I drive it home (about a 65 mile drive). It drove great except the one time I tried to floor it again and had the same symptoms at the same revs but otherwise was smooth as butter (at least as far as I could tell, never had a 2uz before so I don't know how they feel at tip top shape).
Anyways get home and later Friday went to the grocery store and it stalled in the parking lot. Got the odb2 reader out and it came up with a b2799 code for the immobilizer. Looked into that and after talking with my former mechanic roommate figured that the PO had simply realized that he only had one key, had another one cut and didn't have it programmed and so when I used that key it started making the immobilizer freakout (although it should have done that immediately. Anways over the weekend it happened again with no codes then a third time and three p035x codes popped up (can't remember exactly which ones) relating to ignition coils. My mind was still thrown off by that initial BCM code though and so I was still going down that rabbit hole. and so I did a ECM reset by jumping pins 4 and 13 on the odb2 this morning.
Regardless though it's happened a few more times sometimes with ignition coil codes thrown sometimes not. I started correlating it to happening only when the engine was warm (always starts right back up once it's cooled). Popped the hood later in the day and noticed that the coils were not labeled Denso (were OEM coils not labeled on these or are they likely aftermarket replacements?). Pulled one of the coils and one of the plugs and noticed the plug had a VERY worn electrode. Decided tonight to replace the plugs with new NGKs. All plugs were very worn (I'll post a pic here in a sec).
Anyways went for a test drive with roommate following behind and made it about a mile and a half from my home and it died even with the new plugs. Threw p02352 0353 and 0354 so not all of them. My research basically at this point is telling me that this had worn plugs (they were NGKs btw) and this apparently can lead to coils burning themselves out. Perhaps I was just unlucky in that the plugs got just bad enough on the drive home after picking up the vehicle that it caused the coils to start burning out rather quickly. They still have low enough resistance with a cool engine but as soon as it get's warm the resistance get's high enough to where they start failing.
Does it seem that I'm on the right track and my best bet at this point is to just replace all the coils (which I would want to eventually get them all back to Denso anyway, I know how aftermarket parts are on a lot of components with Toyota especially nowadays)? I'm worried that I'm chasing the wrong symptoms and that it could be a bad PCM but the symptoms of only failing with warm seem to be strongly leading me to the coils and the BCM code was just a red herring (it never popped that code after I cleared it and I've only been using the Toyota key). I don't want to go full parts cannon here but I never dealt with engine issues on the 4runner so I'm a little bit more of a greenie here than I am with suspension.
Here's the plugs btw. Super worn electrodes and one of them does have some minor fouling.
