So I had a check engine code 26 pop up the other day. Truck started to run like poo-poo when idling or stopped. It's been a while since I replaced both sensors so I picked up a set from Stevinson today and started diving into it. Yes i did diagnose a bunch of other potential O2 issues prior to buying the new O2 sensors so don't go down that rabbit hole please.
I pulled both of the old sensors with ease. The innermost sensor, wire protection sleeve was original and rotted. It completely fell apart so I removed all of it. Once l removed all of the old sleeve I noticed that one of the wires on the harness side was partially insulted. What I mean is, the wire at the top of the harness starts out as blue but about 6 inches from the connector plug it was stripped back and the metal insulted wire that goes around the inside was just sitting there around the inner wire, which is white.
Has anyone else seen this before on a factory wire harness before? Looking at it it doesn't appear to have been stripped back by someone prior. It looks like when they built the harness at the factory they stripped it back too far and didn't remove the inner wire insulator, they just wrapped it around the inner wire then wrapped it with the wire protection cover and taped it.
Hopefully the photos below show enough detail.
