CardinalFJ60
really!!
it's like gettin' the band back together! I gotta get my 40 together next week!! (fingers crossed)
I could strap a 40 bezel to the front of my 60 and no one would be able to tell the difference................... right??![]()
Well, I was thinking about a "Rusty Old Toyota Run" - The ROT Run. Someone suggested the criteria to be: "25 years or older Toyota and bonus points if you have at least one rust hole big enough to pass a Chipotle burrito through". I thought that was perfect.![]()
So I put my 40 up on jack stands after some challenges on Holy Cross this weekend.
Rut ro....what happened? HC will definitely find any trucks weakness.
Broke the tension pin in the steering shaft to the Saginaw gear box going thru French Creek so ended up using a clip from the Gecko's HiLift and the electric fan thermostat was working intermittently causing the engine to run hot and like crap....so I ended up wiring the fan directly to the battery to get back down the trail and then home. Also looking to ditch the carb and go to TBI so it just runs better overall and will probably pull the head off while I'm at it and have it redone too. So limited to runs that Idelle's open 80 with 33's can handle for now.
Bummer dude.....as for wheeling an open 80 just ask Schlegs how much fun that is![]()
It sucks!!! Things spin. Rocks fly. You stay. Dave you have a lot of projects on your to do list. A stitch in time saves nine, is so true. After the blow off work run, I figure I got through a couple of spots on dumb luck (and experienced eyes spotting me). Took some lines that I was not built for nor was my skill level where it needs to be for them as well. It opened my eyes to the fact that I need to fix some stuff and upgrade others before I go on particular runs. Plus I need to learn to wheel differently on rocks verses the mud I am use to.
Robbie taught me how to power brake and that made a huge difference in what I could do. ...
Power braking - With the left foot on the brake, rev the engine up to 1000 RPM, use your left foot on the brake to control momentum while keeping the engine RPM constant.
My grandma drove with one foot on the brake pedal and one on the gas pedal too...
How long will it take to do the run? We have tickets for a show at Red Rocks that night.
Robbie taught me how to power brake and that made a huge difference in what I could do. I have seen people with open vehicles go through areas that locked rigs have problems with. Why?, because of tools like power braking, knowing how to pick a good line and not overpowering through an obstacle.
