Finally got time yesterday to finish replacing the aftermarket cheapy injectors with OEM injectors on the 85 T4R. The original connectors were half broken and brittle so I replaced the wires with solder and heat shrink. Reinstalled everything and when to fire it up and it just turned over with no start. It did fire briefly but would not stay running. The injectors are the only thing I did, nothing with timing, fuel, or ECM.
Per the Google, the connectors should show 12V at the plug with the ignition on. None of them do. I tested the wiring in front of the pig tail splice and no voltage reading there either. I plan to pull the upper intake off and test the olms of each injector to rule out having a couple bad ones. I have a set of the newer style injectors that I could try, which means I need to change the connectors since they are different.
I may have mixed up which connector goes to the correct injector since I spliced the new connectors weeks ago and did not label the order (dumb move!) but I'm pretty sure I have them in the correct order. I wouldn't know how to verify unless I look at another 22RE for the routing.
I'm reaching out to see if anyone else has any other ideas. I know my way around a 2F and 1FZ but am a noob with these 22RE's. Thanks.
