2 Wheel Drive content... 67 Stout
who knows could be same supplier?
Would Murakami have made the mirrors for the Stout? According to their website they didn't become a supplier to Nissan until 1979.
Kurt question. I have no idea.
Funny I just came across this article. I guess now I know who got that Ebay mirror!
The fender mirrors below must be the older part number and the one I pictured before is the "new" part number.
(I really need to track down some good hubcaps, headache rack and flaps!)
Stout compared to Tundra. :)
So glad I found this thread. Stay tuned for a “copy cat” style revival on my stout but with far less skills and knowledge haha. Love this group 👌
@Bartons_Supra If you haven't, join the Facebook group too, and post up a build thread here for us!
@SteveH sent me an oem wheelchock and motivated me to hunt down the rest of the tool kit for the Stout. Thanks Steve!
The Stout tool kit is similar to the FJ25 and early FJ40 kits and comes in a metal toolbox that clips in under the passenger seat with the jack, which is a stubbier version of the 40 jack. (and has a weird, rubber, stripper-thong styled hold down strap that has somehow lasted 60 years! )
It was below zero wind chills here Monday, and its 90 degrees today! Time to dust the old Toyotas off and get them out of hibernation. 😉
Little things getting crossed off the Stout to-do list:
The front bumper has been crooked since I got it. Finally pulled it off this weekend, straightened the mounts and got it back on.
Finally found a battery top bracket that fit this M24. New correct elephant ear wingnuts in place and battery secure.
Finally found a spare tire carrier! Surprisingly hard to find. I guess a lot were taken off to run aftermarket rear bumpers, or just got mangled. Similar to FJ45. One of the mounting brackets was buggered up but I got it welded up and straight. Handle threads were pretty crusty, but I got them working. Going to do a little cleanup under the bed before I mount it up.
Noticed one of the rear wheel cylinders leaked some while sitting over winter. Tearing into those again too. I found a set of Crown cylinders in Japan I'm going to try.
zgfiredude
Wincher
Silt, CO
in response to your earlier mention of hub caps......maybe this could help?
From my research I had found that the Crown rears are the same as the Stout, im hopeful its true!
Thanks for the tip! Those are actually RK100 heavy Stout caps for 15 inch wheels. The RK41 Lite Stout like mine used a smaller chrome cap and has a 14 inch wheel. Still searching! ;)
zgfiredude
Wincher
Silt, CO
Thanks for the tip! Those are actually RK101 heavy Stout caps for 15 inch wheels. The RK41 Lite Stout like mine used a smaller chrome cap and has a 14 inch wheel. Still searching! ;)
Well d@%$!
I got the spare tire carrier mounted up. I think I figured out why no one runs them. Only a pizza cutter stock size tire will fit! :p my 205R14's are too big. Going to have to find a super skinny spare.
While I was under there cleaning up, I decided to add some mild lowering blocks and new u bolts. The truck had some serious rake. The lowering blocks actually leveled it out nicely.
Those brake hard lines are not my handy work. Making new ones on the to do list!
Nice and level!
Found the rare, optional, reverse light awhile back. It's the same as early 40 series. The wiring is all there and it's listed in the parts manual, but I've only seen one mounted on a Stout and it was a non-usa rk100 heavy. It didn't come with a bracket, so I fab'ed one up and mounted it drivers side where I found the matching wires on the tail light harness. No power yet, so I'll have to crawl around under the transmission to check the switch and maybe pull the instrument cluster. Hunting for the OEM mudflaps and a good set of hubcaps still!
A little crusty, just like the Stout (and me).
