SLO4RNR
Brand New
- Joined
- Mar 6, 2025
- Messages
- 8
Here's the issues I'm having...
We've owned this LC since January 2025 (so semi-new to us) and has 80,500 miles. Everything has worked fine since we bought it and have had no issues.
Two weekends ago we were driving back from Great Sand Dunes NP. We use the Tape Deck with aux cord to listen to music from my phone. We noticed the tape deck randomly clicking then resetting, like it was powering off then restarting. Thought, hmm that was weird. But then it worked for the rest of the 3 hour ride home. The following weekend we noticed that the clock was resetting to 1:00 after starting the engine, also weird. A couple days later my wife ran an errand, came back to the vehicle and there was no electrical power at all, similar to the battery being disconnected. We have a quick disconnect on the negative terminal. I had her flip that up to disconnect and then push it down to reconnect. Electrical power was then restored and she was able to start it and make it home. When I got home, the LC again had no electrical power. I flipped the negative quick disconnect on the battery and reconnected and the power was restored. I checked all the terminals, everything was tight, no corrosion. Tested the volts with a multimeter and was getting 12.36v. I started the engine and tested the volts at the battery again and was getting about 14.2v with it running. I removed the battery and took it into the auto parts store to test. The battery tested good, but they said the volts was at 12.2v. and recommended charging it. So I got home, reinstalled the battery, cleaned all the terminals, reconnected the battery and put my NoCo trickle charger on the battery overnight. Checked in the morning with the multimeter, and it tested at 12.6v. Also checked both sides of the negative terminal quick disconnect to rule that out, getting 12.6v at each side. That connection is super snug and getting the same volt reading on both sides, so ruling that out. The next day my wife drove the car and everything worked fine, no issues. Today when she drove, the the tape deck thing started happening, then she got back into the garage. When she turned the engine off, there was again no electrical power (no dome lights, power locks not working.... She got out by manually unlocking. 10 mins later she went back to the LC to get some things out of the back, and when she opened the rear hatch the dome lights were working (she didn't do a reset on the -neg cable on the battery this time). Ugh...
Has anyone experienced anything similar? Any advice on what to check next would be greatly appreciated! I'm going to go home at lunch and try to diagnose for the rest of the day. I'll test to see what the volts are reading at the battery is now (48 hours after reinstalling and driving)
Any fuses to check? Ground cables? Alternator? Is it something to do with key transponder perhaps?? Idk, i'm at a loss right now. Any advice or recommendations would be greatly appreciated. Just stumped by the complete electrical loss after turning off the engine...
Cheers!
-Brian
Cheers!
-Brian
