I had a great weekend working on Genni. I got A LOT accomplished on her!! So for only having one major thing take a crapper I'm counting it as a productive weekend.
1. Took her top off!
2. Took the CVT Awning off to sell it with the tent walls. (Hmu if you're interested)
3. Replaced the passenger front fender & massaged it to fit the door hinge & adjusted the turn light housing to fit it.
4. Ran wiring for the Auxbeam to have power without the ignition turned on, but added a switch so I can disable it & not drain the battery.
5. Cleaned TF out of the cab that was covered in Arkansas mud.
6. Removed the faded windshield banner. I'll have to cut a new one with better vinyl that won't fade so quickly.
7. Installed the hydraulic hood struts,
which led to the EFI regulator needing to be moved, in turn broke an old wire on the connector, & the fuel regulator being screwed up in the process & she was spewing gas all over the place....
(Parts are ordered...)
8. Ran wiring for the two cab speakers & power for the radio that I'll be installing soon.
9. Cleaned & Installed a vinyl cushion wrap on the rear roll bar that I bought off a wrecked 1st Gen.
10. And lastly I replaced the shifter knob with a pretty purple one!!
The list is getting shorter!!! Even though it doesn't feel like it!
She's scheduled to have the aformentioned suspension & steering upgrades done a week from now. So I'm hoping to get most of the stuff done that I can handle this week.
