Talked to a gentleman at Advance Adapter. He's heard of this problem before. The issue is the Marlin Crawler 4.7:1 full length splines are too short versus the Advance Adapter dual bearing coupler expected spline depth. And the old Advance Adapter single bearing coupler is a different length and thus incompatible.
So the guy at Advance Adapter said I can either grind material off of their coupler splines or off of the Marlin Crawler gear input shaft splines. Or get different 4.7:1 gears. Or switch back to 2.28:1 gears.
I'm thinking grinding is the answer and I think that probably the input shaft coupler would be cheaper to replace if I screw up. I could gingerly attack it with a Dremel tool. I need to gain somewhere between 1/8" and 1/4" of extra room.
Does that sound reasonable/logical/safe?
