Zirc fitting
Centennial, Colorado
It was a 6M zirc and I got it at pep boys. I replaced it with another straight one because I could not find a 90 degree locally
It was a metric set that had several sizes in it
Thanks guys.
Jeff - If I haven't picked up any by the time June rolls around, I'll take you up on your offer. But I suspect I'll need a few spares on hand anyway, as it took no effort at all to snap the first one.....
So Ken, did you get the Zirc grease fitting put together so you don't have to pull one end of the drive shaft to lube the u-joint? I just did this last night -- what a PITA.
No, Couldn't find a right angle at the right size and pulled the shaft. Turns out the zirc was plugged so I replaced it. Not sure how much the plugged zirc contributed.
heh, heh.. he pulled the shaft... :lmao: :bolt:
Hey Matt do you have the special needle deal for the DC shaft?
